Rattling with Hurst Shifter
Looks like I might have to open mine up and apply some of the grease. At first the rattle was minimal, but it's started to get louder over time. Generally it doesn't bother me, cuz I have the windows down and the radio up, but when my wife is riding with me, I hear it. Looks like another project.
It is defective for sure, and I should have done something about it. I was just so annoyed with Hurst that I did t even want to mess with them at the time. How could a company with such a long history of making quality snifters make a piece of crap like that. Now I'm sure it's too late.
LOL That sounds like a new cartoon...
I have the rattle but no play in the shifter. I filled in the base with Mobil 1 synthetic bearing grease and the noise is like 70-80 percent reduced. I tried to get it filled in around the bearing but that was nearly impossible so hopefully over time and use it will pack in the bearing. I pretty much applied the grease heavily in the cup shape until it was nearly full.
For the guys who are concerned about the notchiness in the shifter, I think you just need to get use to it.....especially if you have not used a short shifter before. I think the notchiness gives it more precision and I am finding my Hurst shifter to be awesome upgrade.
It feels like I am playing one of those old school arcade driving games!
The vibrations seem to have settled down with the neoprene insulators from Hurst and a little Lithium grease in the ball joint that has been discussed extensively here
If you guys look at Taco Bill's thread on the MGW shifter install.....you will see MGW uses a lot of insulation which I think why very few people have had problems with MGW. With all the new Hurst shifters, you should be getting those neoprene isolaters which should dampen vibrations.
This is an old thread, but did anyone slip the lower opening of the factory rubber boot over the black "flange" of the Hurst so that it wraps around the base of the shifter? Or did you just plop the rubber boot back into place? The factory shifter uses the lower boot as a seal against the base of the shifter, and the top of the rubber boot forms another seal with the shifter handle itself.
Yes I did use the lower boot and this grease.
http://www.autozone.com/greases-and-...?checkfit=true
From: the beautiful "Shenandoah Valley of Virginia"
When you guys talk about greasing the shifter, you are referring to packing a heavy grease from the top into the black base?
My Hurst boot tore (the one at the bottom of the shifter) and I found out that this boot provides the "return spring" action of the Hurst, at least on the billet version. Once it was torn the shifter would rattle around. Hurst wanted me to buy a replacement, since I had bought my Hurst a few months before they implemented the lifetime warranty.
I fixed the rattle by installing a MGW, which was significantly better in quality and design.
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
