Radiator Hose help
Radiator Hose help
Radiator Hose help
I'm trying to replace some of my black rubber hoses with steel braided hose. I'm looking at the overflow tank hose that goes to a tee with the lower Radiator hose. How does it come apart? It looks like there is no clamp but it doesn't pull off. it almost looks like it is pressed into the tee.
This is a 07 GT/CS.
Any help would be great thanks
This is a 07 GT/CS.
Well I got it off but man what a screwed up way to tee off the hose. Instead of some type of clamp they used a plastic band that was connected to the other 2 plastic bands. It was a standard 1 1/2" id tee that is barded to hold the hose on, but to clamp it on the hoses it has plastic bands and all 3 are connected together. I had to cut the middle band off the other 2, than cut the band off and then the hose would come off.
