Quick Q: Will this spring compressor work on our springs?
Old Mar 20, 2007 | 09:02 AM
Chaotic Bliss's Avatar
I think it will, just wanted to double check.
http://ultimateperformancecar.ca/ite...116-detail.htm
Old Mar 20, 2007 | 10:17 AM
mvon919's Avatar
Yes.
Old Mar 20, 2007 | 10:41 AM
RobK's Avatar
Just be consciencious of how you've got it set up. I've seen folks go a little overboard tightening down the u-bolts to the point that they break when they're cranking down on the spring. They're only there as a safety measure, so keep tabs of the tension on them. Also make sure that they get them as evenly spaced as possible around the spring or they'll try to "walk" on you.
Old Mar 20, 2007 | 07:13 PM
sjstrayer's Avatar
I got mine at harborfreight.com. Search for item number 3980-6VGA. Worked well for me and cost less than what you are looking at.
Old Mar 21, 2007 | 06:53 PM
RadBOSS's Avatar
I have had a set like that for 30 years. Works great. Keep the threads clean and lubricated. Keep the pullers 180 degrees apart. Tighten each side down a little at a time to keep the load balanced.
Old Mar 21, 2007 | 07:03 PM
Cheese302's Avatar
yes they will work fine. i have a set of my own as well. just keep the loa balanced, count the number of turns on each side.
5.M0NSTER
26
Sep 28, 2015 07:11 PM
dohc97
16
Sep 24, 2015 05:40 PM
Last1
Sep 5, 2015 01:23 PM
RocStar69
Aug 21, 2015 07:33 AM
jim010
Aug 4, 2015 02:49 PM
