QA1 rear shocks
Old Jun 22, 2005 | 05:05 PM
169stang's Avatar
[attachmentid=25307]Installed these last night. Only took maybe 45 minutes. More time getting to the shocks than actually changing them out. The track is closed tonight due to weather, so I'll post feedback next week on them. I talked with Justin (JPC) today. QA1 is working on a front strut and should have them very soon-atleast that's what he said to me.
Old Jun 22, 2005 | 05:18 PM
wild stray's Avatar
Is that double adjustable?
Old Jun 22, 2005 | 05:20 PM
tmcolegr's Avatar
From where & how much? Street or Strip or street & strip. I have been looking for a good quality rear shock for street use.
Old Jun 22, 2005 | 05:22 PM
169stang's Avatar
Single adjustable. I didn't see the need for the double adjustable in the rear, especially for almost twice the price. I bought them from BMR. http://bmrfabrication.com/2005Mustang.htm
$149.95 to answer your questions.
Old Jun 22, 2005 | 05:50 PM
wild stray's Avatar
Thanks!
Old Jun 23, 2005 | 08:41 AM
porsche's Avatar
did you have to put in washers for the shocks to fit?
Old Jun 23, 2005 | 02:02 PM
169stang's Avatar
The shocks came with everything to mount them right up. What would you use washer's for? There is a washer that backs the rubber bumper where the upper portion goes into the body and the same on the inside of the trunk. As far as the bottom, there is two collars that slip on the outside of the insert that the bolt runs through.
Old Jun 23, 2005 | 02:08 PM
porsche's Avatar
when they first came out the bottem of the shocks needed washers or a spacer somebody said on this forum i was waiting for the fix qa1 said they did not have a kit out so bmr was making them.
http://forums.bradbarnett.net/index.php?sh...ic=22264&hl=qa1
Old Jun 23, 2005 | 02:53 PM
169stang's Avatar
The kit I installed mounted right up w/o any problems. Spent more time getting it on jack stands than anything else. I did have to put a socket on the threaded portion on the top of the stock shock to keep it from spinning while I removed the nut. Other than that, it fit right in. It did come with 2 shorter sleeves in the box. The sleeve that was on the bottom had 2 larger sleeves on the outside. It looks as if BMR made these, put them on and it comes with a zip tie holding the sleeves on. Very simple mod.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
ricky1728
Feb 11, 2016 07:25 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
