Proper wideband bung position and install?
Old Nov 12, 2009 | 01:55 PM
eighty6gt's Avatar
I'm not real keen on having an exhaust shop smoke a hole in my factory H pipe and weld a bung in place... mainly because I don't want a bunch of chips bouncing around between the cat and the engine, possibly winding up in the cylinder. People's cat's disintegrate and end up in the engine, why not metal filings? Am I being paranoid?
Also, I was reading in other threads the bung/plug/sensor should be installed between the 10 and 2 position on the pipe.
I'm thinking of removing the H pipe, plugging off the downstream side, drilling a hole in the proper location and having a stainless bung welded in place.
Does it matter which side I weld the bung on? I'm thinking the pass side would be easier to access to thread in the wideband sensor.
Thanks in advance for any advice.
Old Nov 12, 2009 | 06:28 PM
tom281's Avatar
If you have a bung installed on the factory pipe, just make sure it's before the cats. Mine was on the passenger side, until I went to an offroad H.
Old Nov 15, 2009 | 08:25 PM
Embalmer's Avatar
Mine is installed in the driver's side rear O2 bung which faces @ 9:00. Of course, I don't have any cats and L/T headers.
Old Nov 15, 2009 | 08:57 PM
eighty6gt's Avatar
I spoke with the tuner on Friday, he said that the drivers side is where you want it since that bank can run a bit leaner... also anywhere above horizontal is ok. He said all you don't want is water condensing on the sensor, one drop of water can kill it.
Automagically
2012-2013 BOSS 302
37
Feb 19, 2020 09:28 PM
unnoticedtrails
Jul 17, 2017 11:10 AM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
SMOKE46
Sep 6, 2015 09:40 PM
