Possible fix for owners of Hurst/Tri-ax shifters w/ vibration
Old Apr 11, 2006 | 01:37 PM
LonghornTX's Avatar
I have noticed recently that Steeda has put out a kit that supposidely fixs the vibration from shifters like the Hurst and Tri-ax. I have not noticed it on their website but instead on a private vendors. I cannot seem to recall which one at the moment but I just thought I would put this out there for the guys that are having vibrations problems. The kit itself looks to be pretty simply, basically a piece of rubber to go in between the the shifter assembly and the shaft that holds the shift ball/**** at the connection with the two-bolts. Seems like it would reduce the 'tuning fork' effect a bit, and it is cheap (like 8 bucks). Anyways, hope this helps.
Old Apr 11, 2006 | 01:41 PM
TorchRedBeauty's Avatar
<div class='quotetop'>QUOTE(LonghornTX @ April 11, 2006, 3:40 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Great find! Do you have any links to this kit?
Thanks,
TRB
Old Apr 11, 2006 | 06:00 PM
LonghornTX's Avatar
<div class='quotetop'>QUOTE(TorchRedBeauty @ April 11, 2006, 1:44 PM) Quoted post</div><div class='quotemain'>
Thanks,
TRB
[/b][/quote]
No, but I bet if you called Steeda they would know exactly what you were talking about. I bet you could probaly even make it yourself if you had time. Basically a relatively thin piece of rubber with holes for the two bolts to go through... [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Kind of something like this
Old Apr 11, 2006 | 07:14 PM
dustindu4's Avatar
9 is not my lucky number.
That rubber piece is standard with the Tri-Ax shifter and it still vibrates. See the very end of the tri-ax thread in my sig how I fixed my vibration problems. I haven't had any issue since.
Old Apr 11, 2006 | 07:35 PM
LonghornTX's Avatar
<div class='quotetop'>QUOTE(dustindu4 @ April 11, 2006, 8:17 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Oh well then. I did not know if had been tried/used.... [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Jul 8, 2016 08:53 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
oldnjguy
Sep 10, 2015 02:39 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
