PMP Line Lock Kits, looks good!
Well I found some more line lock kits, this one is from pmp, and it has braided hose lines, so no bending, also has the two solenoids that look like granatellis. anyone ever used these?
http://www.pmpparts.com/index.php?ma...du cts_id=187
With the PMP kit you don't have to worry about cutting your stock lines. You don't have to purchase unneeded tools such as a tubing bender, double flare tool, and tubing cutter that you would probably only use once.
The trouble of bending lines and the dreaded double flaring is eliminated. You just get a nice box full of parts that bolt right on
- Direct Bolt in (No Cutting, Crimping, or Bending).
- EASY Installation.
- PTFE Stainless Braided Hose
- Uses tested and proven Summit solenoids.
- Dual solenoid design does not interfere with ABS/Traction control.
- Easily return to stock if the need arises.
- Out of sight, does not clutter up the engine bay.
- Does not interfere with aftermarket front suspension components.
- Simple Installation with Basic Tools.
- Add-A-Fuse included simplifying wiring.
I have this kit sitting in the house now. Waiting for SS lines and rotors which are in the mail so I can do the whole thing at once and only bleed the brakes once. The solenoids are from Summitt.
Oh yeah, and PMP is awesome to deal with!!!
ssjbuu
8/28/15 08:55 AM
AMWill
7/20/15 08:40 AM
