performance clutch options.......
Old May 21, 2006 | 09:02 PM
dustindu4's Avatar
9 is not my lucky number.
Originally Posted by jp's performance
that some funny $hit dustin.
you ever seen his lawnmower?
It's "sponsored"
Old May 23, 2006 | 10:17 AM
300HPGT's Avatar
ram or centerforce is my choice both work good for me,i have the centerforce df clutch stock flywheel for now going with spec or hays 12# flywheel i did have to take off the stupid weights and it shifts fine now,just need a new tranny and i will be able to shift at 6500 again.
You need a new tranny?????? I would be interested to hear why. I am in the process of replacing my clutch in my car because the stock one is shot. I replaced it with a ram clutch and boy is there WAY more surface area on the ram than the stock clutch. But I am trying to trouble shoot a transmission problem because Ford was giving me the run around saying my clutch was the problem and not my transmission. It grinds when you shift from 1st to 2nd. So let me know what is up with your trans.
Old May 23, 2006 | 10:23 AM
300HPGT's Avatar
what is this talk about shims???? What is that little plate that is sent with the ram clutch??? Also there is no replacement throwout bearing with the clutch. Not even the autoparts stores carry them yet. Are you supposed to put that shim behind the hydraulic assembly to push the plunger forward? These are all important questions i need answered asap because I still have yet to torque down the transmission bolts. I just dont want to have to bleed the clutch again. that was a pain in the a$$.
Old May 26, 2006 | 09:34 AM
RRRoamer's Avatar
Originally Posted by RPM
OK, fair enough. Over the years I have used Centerforce Dual Friction clutch kits in GM applications. Specifically the 11" clutch with either 10 or 26 spline discs. What I and many others have reported on other boards is incomplete release between the plate and disc. I found in this problem with several plates I have run and have personally seen it in other cars. What I found were the weights installed on the pressure plate diaphram fingers shifting off center and distorting the pressure plate diaphram spring. These pressure plates at least in my application are Valeo units so I called Valeo and spoke to a tech about them. He indicated that Valeo sold the plates to Midway Industries (owner ot the Centerforce brand) and that Midway installed the weight rings and painted the covers. I purchased a stock replacement Valeo plate and compared it to my "hi perf" Centerforce. The only noticable difference were the goofy weights which can never work IMHO and a crappy orange paint job. The Dual friction pressure plate, at least in GM 11" applications is nothing more than a stock replacement plate with a bad paint job, a cute little sticker, and some half-arsed weights that cause nothing but problems.
Their (Centerforce Dual Friction) disc on the other hand seems fine.
I'm just pissed at this company for passing off what is supposed to be some great clutch kit which under closer inspection is just some scamed up gimmicked-out stock pressure plate. BTW, their customer service is just like their pressure plates, suck!
Does this answer your question?
Thanks RPM. That does indeed answer the question.
Old May 26, 2006 | 11:27 AM
RPM's Avatar
RPM
I want to apologize if I came off abrasive. After my experience with this company and how they represent their products I tend get this way. Maybe Centerforce has a good clutch (that is a real performance product not a painted stock replacement) for our Mustangs but I would take any of their descriptions with a big grain of salt.
Old May 26, 2006 | 02:19 PM
Firedude's Avatar
It is good to get as many comments as possible about a product. Good or bad. I have good with this one but now have that grain of salt before my next clutch purchase. It would be nice to hear from someone who has a 05-06 Centerforce. Because of your bad experience I will be looking at several options instead of one.
Old May 26, 2006 | 02:23 PM
RPM's Avatar
RPM
There is a thread going on now about the '05-06 Centerforce clutch on Corral.
Old May 26, 2006 | 02:40 PM
jp's performance's Avatar
it does not have second gear anymore,it grinds going in third gear,i just bought j.r granatelli's 3650 from his 05 with 700 miles he went with a 6-speed for $660.00 to my door and then i am going to have my buddy pro shift the 1 that's in the car right now.
Old May 27, 2006 | 09:15 PM
300HPGT's Avatar
Thats awsome man!!!! I really need to get a new transmission. My 1st gear is shot and it grinds into 2nd and 3rd now. I will race prep the blocker rings in the trans if i can get ahold of a 3650. But I called Tremec and they said that they have 3650 parts on hold to all of their distributors because of the high demand for the transmissions from Ford. Their aftermarket has been put on the side a little bit because of this. I want to get a rebuild kit asap but I think i will have to live with the trans the way it is for about 3 - 4 more months if I cant find anyone with a used 3650.
Old Dec 28, 2006 | 03:23 PM
Hatchman's Avatar
Originally Posted by Black3V
ok I see nobody has mentioned Spec. When replacing the clutch and flywheel with theirs then there is no shims needed. I have been running the stg3+ with aluminum flywheel for about 9 months with very nice street manners and great holding power. I have not exactly been easy on it either with consistent low 1.6 60 ft's at the track.
Reviving old thread:
I'm getting a Spec Stage 3+ with Fidanza AL flywheel, this is good to hear.
May 3, 2026 05:42 AM
Gill5oh
Oct 6, 2017 10:50 PM
GeoWett
Sep 30, 2015 06:40 AM
oneeyedgiant
Sep 29, 2015 01:33 PM
Evil_Capri
Sep 25, 2015 12:56 PM
