Which Panhard Bar BMR or Spohn?
Old Mar 31, 2008 | 08:58 AM
nm3's Avatar
nm3
I have Tokico hp shocks, Steeda Ultra Light Springs and 20" Shelby Razors (24mm offset) all in transit. I'm anticipating needing an adjustable panhard bar to center the axle as any variance will be quite visible with the wheels pushed out to the fender well lip with my wheel choice.
I'm looking for opinions on an adjustable panhard bar. After some research, it appears as if I have narrowed it down the BMR or Spohn with bushings on each end based on maintaining ride quality, ease of adjustability, securing the lock nuts after installation, appearance of quality and price.
Good choice or not? Is there anything better out there? Spohn is available in all Chrome Moly, should I concider that?
Any help is appreciated....
nm3
Old Mar 31, 2008 | 09:11 AM
LEO_06GT's Avatar
Have you considered Steeda? They use poly bushings that don't require maintenance.
Old Mar 31, 2008 | 10:50 AM
nm3's Avatar
nm3
I have. But, in one of the write ups, I think, I saw that it was difficult to tighten the lock nut on the passenger side with an open end wrench. I'm thinking, its not good if you can't get at the nut to tighten it well. Plus it costs more then many others.
Old Mar 31, 2008 | 05:44 PM
Fman67's Avatar
Spohn
nm3
I have the Spohn..in red...looks great,nice fit and finish. Mine has the poly bushings with ghrease fittings. Adjustment is really easy and easy to get to. Once you get it centered where you want it...just tighten up and you never touch it again. I used a dot of Threadlocker...hasn't budged loose yet!
Old Mar 31, 2008 | 06:22 PM
MooStang05gt's Avatar
I am using the BMR adjustable swaybar, it too is a very high quality piece, easy to install and to adjust, has the poly bushings with grease fittings. Mine has been istalled for 2 1/2 years and is greased evey time I have the oil changed. It hasn't moved since being installed.
Bobby M.
Old Mar 31, 2008 | 06:38 PM
05GT-O.C.D.'s Avatar
I lust for a M24
What's the advantage of Chrome Moly?
Old Mar 31, 2008 | 06:50 PM
nm3's Avatar
nm3
Stonger steel then mild steel. So, the bar would weigh less and have the same strength.
Old Mar 31, 2008 | 07:08 PM
I lust for a M24
How much can these things weigh? What kind of weight savings I wonder.
Old Mar 31, 2008 | 07:57 PM
Not to hijack but I have the BMR and as said above easy install, easy to get to, and easy to grease. Did anyone else notice the stock panhard bar felt like it had lead shot in it? When you shook it it rattled.
Old Mar 31, 2008 | 08:06 PM
nm3's Avatar
nm3
I think I read in a post on another site which said the weight savings was about a pound.
I also saw in another post that someone made the comment about some material inside the bar as a vibration absorbtion measure.
Old Mar 31, 2008 | 09:28 PM
blkstang06's Avatar
its not lead shot but metal shot mixed with rubber shot, 70MACH1OWNER has photos of the actual material.
I think I read in a post on another site which said the weight savings was about a pound. the factory bar weighs about 9 lb's If you go with J&M's PHbar it weighs 3 lb's.....
by Category 1979-2004 MUSTANG 1982-1992 Camaro / Firebird 1993-2002 Camaro / Firebird 2005-2008 MUSTANG by Manufacturer F-BODY (camaro - firebird) Mustang
2005-Pres. Ford Mustang Billet Aluminum Double Adjustable Panhard RodMustang - 2005-2008 MUSTANG#23757
Click to Enlarge
Click to Enlarge
Years:
2005, 2006
2005 Ford Mustang - Street/Race Adjustable Panhard Rod
Our tubular adjustable panhard rod is the finest on the market today. Manufactured from high strength 1.125" x .210" 6061-T6 aluminum, our ultra light panhard rod will eliminate unwanted flex and twist. The panhard rod will give you the competitive edge by keeping the rear axle located in the optimum position under the rear of the car. Thereby, dramatically improving cornering and overall handling predictability. The rod can be easily adjusted on the vehicle to compensate for ride height adjustments. Our panhard rod features machined wrench flats with left and right hand threads allowing fast and accurate adjustments while still on the vehicle.
Only $139.82!!
Qty: Home | About Us | Products | Specials | Links
Thats what its for !
robjh22
Dec 14, 2015 08:41 AM
RoushRS3
Sep 29, 2015 08:03 PM
Airborne42
Sep 25, 2015 05:14 PM
Evil_Capri
Sep 25, 2015 12:56 PM
robjh22
Sep 8, 2015 12:31 PM
