Oops, melted the same plug, again...
Old Feb 25, 2006 | 07:59 PM
psfracer's Avatar
Ok, so at FAMOSO today I ran a 12.300 with a 1.647 60', but at only 103.81.....I lifted at 1,000 feet because something wasn't right. So, based on prior experience, I checked the driver side front spark plug, and yep, its melted again.
So, my question is has anyone ran into this? I find it strange the the driver side front is the only plug I am losing and all the others look fine. Plug was 1 step colder then stock, 96 octane gas (5 gal 91, 5 gal 100). What fuel pump is everyone using out there???
Any info on pumps, or theories on why only the driver side front plug????
Old Feb 27, 2006 | 08:44 AM
psfracer's Avatar
A lot of people are recomending the Boost-A-Pump. Anyone here actually run one, are you happy with it? Is it hard to install?
Old Feb 27, 2006 | 02:40 PM
Cleveland's Avatar
Are you doing any datalogging during the runs? Fuel Pressure isnt neccessarily your problem here.
Also, what shot are you using? If its a 75-100 with Zex your fuel pressure should still be "A OK".
-Dan
Old Feb 27, 2006 | 09:32 PM
psfracer's Avatar
<div class='quotetop'>QUOTE(Cleveland @ February 27, 2006, 2:43 PM) Quoted post</div><div class='quotemain'>
-Dan
[/b][/quote]
I am currently running the 125. Never had a problem with the 100hp setting, have many, many passes on the 100 and the plugs always looked great. Even many passes on the 125, but most of them was 1/8 mile, so I am guessing the lean condition really doesn't develop unless a full 1/4 mile pass. That to me says lack of fuel, vs too hot of a plug or to much timing, etc. I was also running a N20 tune with less timing.
Old Mar 1, 2006 | 12:22 AM
mikeelia's Avatar
<div class='quotetop'>QUOTE(psfracer @ February 27, 2006, 8:35 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
My uninformed guess is lean condition. Can you datalog the AF ratio? More fuel before you melt a piston! <chuckle>
Mike E
Old Mar 1, 2006 | 01:30 AM
Cleveland's Avatar
at 1000 feet is where my knock sensor went off but I put all 8 plugs out of their misery.
Where do you have your nozzle installed? There could always be a distribution issue.
-Dan
Old Mar 1, 2006 | 07:28 PM
psfracer's Avatar
<div class='quotetop'>QUOTE(Cleveland @ March 1, 2006, 1:33 AM) Quoted post</div><div class='quotemain'>
-Dan
[/b][/quote]
darn, all eight plugs?? Did you end up finding out what the problem was in your case? I have my nozzle installed about 8 inches before the throttle body. I guess I will start with the fuel system only because even if its not the problem, at least when I do upgrades in the future, I know the fuel will be there.
Old Mar 1, 2006 | 09:11 PM
dlc's Avatar
dlc
maybe the front cylinder is getting more spray? How far back is your nozzel?
Old Mar 1, 2006 | 09:28 PM
psfracer's Avatar
<div class='quotetop'>QUOTE(dlc @ March 1, 2006, 9:14 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Its about 8 inches away from the front of the throttle body
Sep 23, 2015 03:21 PM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
