OEM Intake Manifold
OEM Intake Manifold
On my Intake manifold on the back there is a plug, that looks like an O2 Sensor, and i dont see a place to plug it in on the Saleen supercharger or anywhere, can anyone please tell me where the plug that used to plug into my OEM intake manifold plugs into...thank you
ok, i notice though on them, that there is a spot to where it can plug back into its on like harness, kinda like looping it. I plug it in there, i hope that will be ok, cause i already have ran all the tubbing and put everything on, and that would be a pain in the butt to have to pull everything back off to unplug it from itself
I don't have mine plugged into anything, just used tyrap to
secure it to harness to keep it from flopping around.
Only other plugs near there are the O2 sensors and they
are differant color and locater key should keep anything
else from being plugged into them.
If you have your old manifold you should see the drive
motor assy that the plug hooked to and the new program
your running with supercharger will delete the operation
and any fault codes associated with them.
When i deleted my charge motion valves i took off the factory motor to save a little weight and all i did was put some dielectric grease on the end of the plug to keep moisture and dirt out of it and zip-tied it to a cable bundle running behind the intake.
Awesome i totally get it, here is the thing, on that plug harness there is two plugs, one plugs into the old charge motion plate drive motor, where does the second one plug into? or does it
