O2 sensor wide or narrow?
Old 8/17/05 | 01:34 PM
pmcarlino's Avatar
Can somebody confirm it the 2005 GT has a Narrow 0-1 volt or Wide 0-5 volt oxygen sensor?
Old 8/17/05 | 01:57 PM
y22kc's Avatar
I think it's a wideband sensor, but I am not for sure.
Old 8/17/05 | 03:00 PM
2005RedGT's Avatar
Its a wide ? I thought all stock cars had narrow band O2 sensors. You are certain ?
-Bryan
Old 8/17/05 | 03:12 PM
y22kc's Avatar
-Bryan
Hmm, maybe it is. I'm not certain, I should have mentioned that.
Old 8/17/05 | 03:19 PM
Fazm's Avatar
<---also thought they came with narrow.
i say this cuz ive seen posts bout people welding/buyin widebands. so why buy one if it comes with it? so thats why im thinkin its narrow. (and ive never seen a stock car with anything else, and im a mechanic lol)
Old 8/17/05 | 04:05 PM
dhof303's Avatar
It is a narrow band sensor only, it only keeps track of exhaust air/fuel ratio in that fashion, however it can keep track of "commanded" air/fuel mixture with the appropriate data logging like in an XCal2. T see the "actual" air/fuel ratio you will need to purchase a stand alone cpu/processor that can figure this function along with installing another sensor in one or both of your exhaust pipes.
Old 8/17/05 | 09:31 PM
RRRoamer's Avatar
What dhof303 said. Narrow only at all four corners. Too bad the front two arn't wide band. That would be SWEET! Actually KNOWING the A/F ratio straight from the ECU...
trackpack13gt
7/25/17 05:29 PM
samjluck
10/26/15 05:17 PM
10/2/15 01:00 PM
Quick Reply: O2 sensor wide or narrow?
