O2 sensor not plugged in
Hey guys,
I installed my Pypes Off-road x pipe and for some reason could not get one of the O2 sensors to reach and plug back into the new pipe... So i installed a plug and taped off the sensor.... now i'm getting a check engine light and after pulling the code its p2195 (O2 sensor).... now thats not a big surprise since its not connected...
My question is: other than the annoying light will this cause any problems to the car or is it safe to leave it this way?
I had a shop look at it and they wanted $100 to extend the wiring of the o2 sensor so it would reach.... not sure i wanna spend any cash just to get rid of the light...
thanks for any info you guys can provide...
I believe the bank that has invalid input will make an assumption as to the correct amount of fuel to inject, sometimes erring on the rich side. It will cause excess carbon build-up, and poor fuel economy, the degree of which I am uncertain.
started the car and it sounded like it had a cam, rough idle for a few secs. pumped the gas to idle it down (definetly had a rich condition) and went for a ride, well.... the car is now running just fine, sounds great, longtubes ya know... no codes and gas mileage went back up. ran this by SETH @ BRENTS, maybe a faulty O2, may show up again... he did give some pointers to tell if its the O2 next time, maybe there's no next time...... crosses fingers.
Definitely noticed its running a little rich and theres carbon build up on the exhaust tips.... will look into the extenders..... thx for the input guys!
