Which no tune CAI is better?
Old Apr 29, 2007 | 06:16 PM
1200custom's Avatar
Originally Posted by TillmanSpeed
The GMS no tune intake has seen AFRs in the 17s up top end for their no tune option. That's MORE than detrementally lean. Just my own personal opinion... the only no-tune I would trust is C&L, end of story. In that situation, it doesn't cost a dime to take out the insert, and run a tune. Just my 2 cents...
Doesn't the Airaid also have a removable insert as well? I am also looking at a CAI with no tune ( maybe in the future). I just want to understand the difference between the C&L and the Airaid.
Old Apr 29, 2007 | 08:18 PM
m05fastbackGT's Avatar
There's really little difference between the Airaid and new C&L no-tune sleeve option as both use similar sleeve devices which can be installed and removed from their MAF housing's..
Old Apr 29, 2007 | 10:28 PM
extuner's Avatar
I have GMS cai and fuego tuner set for 93 tune and must tell you the car runs fantastic. My question is, why are there so many neh sayers about GMS?...........
Old Apr 29, 2007 | 11:16 PM
JonCo's Avatar
So, what exactly is the deal with this "C&L Trueflow Intake Kit "No Tuner Option" 2005-07 Mustang GT"? What makes it different from the other C&L CAI that it doesn't require a tune(immediatly?).
Just curious... Cause it really works out nice if your someone like me who isn't interested in a tune for warrenty issues but eventually has the option once the warrenty is up to get the tune.
hmm...
Old Apr 30, 2007 | 02:54 AM
Here's why...it's because the re-calibrated MAF and jumper harness will not function properly with the SCT X-CAL II nor Diablosport tuner because the tuning files programmed by Bamachips and Brenspeed are based upon the factory MAF calibration settings only.. Plus the majority of most TMS members also happen to be Brenspeed and Bamachips customers..
Old Apr 30, 2007 | 03:12 AM
hmm...
It uses a similar venturi tube insert found in the Airaid CAI which reduces the MAF housing size indentical to the stock intake tube for those who don't wish to re-flash for warranty reasons but also provides the option to remove it for those who eventually plan on tuning upgrades..
Old Apr 30, 2007 | 06:47 AM
JonCo's Avatar
It uses a similar venturi tube found in the Airaid CAI which reduces the MAF housing size indentical to the stock intake tube for those who don't wish to re-flash for warranty reasons but also provides the option to remove it for those who eventually plan on tuning upgrades..
Thank you
Thats what I'll most likely end up doing. Maybe for the fall/late summer project. Thanks again
Old Apr 30, 2007 | 01:58 PM
NJJOE's Avatar
Well, here was my experience with the GMS W\MAF. I bought the GMS W\MAF and ran it for a few months without a tune. Never once did I get a check light and it ran good. I then decided to go with a Brenspeed Tune and with the recommendation from Brenspeed I was to use the stock MAF with the CAI while running the Brenspeed Tune. Which I did. I then took the car to get Dyno'd and with the Brenspeed Tune and the Stock MAF the car was running 16's for the Air Fuel. So, I had it dyno tune to run a better Air Fuel ratio. So, the bottom line is to always check the car on a dyno to make sure it is correct. The reason that Brenspeed tune may be off was the Ethanol that is mixed within the fuel, at least that is what I was told. Get it checked on a dyno!! Be safe.
Old Apr 30, 2007 | 07:19 PM
thiskidcandrive's Avatar
I didn;t read anybody elses post but you should not run an intake without a tune, it will probably put you into the 15's. Buy the tuner before the intake, better to be rich than poor
Old Apr 30, 2007 | 08:11 PM
You just confirmed exactly what I've been posting all along Joe..Therefore what good is the GMS if your only able to use the stock MAF while running either Brenspeed or Bamachips tunes ? Seems to me that both the re-calibrated MAF and jumper harness are nothing but a complete waste and totally useless, don't you think
Old Apr 30, 2007 | 08:31 PM
eci's Avatar
eci
Get C&L's new "no tune" option. Then you have future upgradability.
Old Apr 30, 2007 | 08:40 PM
karman's Avatar
What is your A/F ratio?
Old Apr 30, 2007 | 08:43 PM
JonCo's Avatar
+1 mhmm
Old Apr 30, 2007 | 09:03 PM
TillmanSpeed's Avatar
Former Vendor
It does have the insert just like the AirAid. They're very similar in design throughout the whole intake. I'm just not a fan of AirAid's products in the past. Maybe they have improved over the last year or two, but they've been lacking in the past. I haven't ever had to run across the intake for the S197 so far. It's actually the only one we haven't had to install or tune. I am a personal fan of the performance of C&L along with Lee (the owner)'s honesty, knowledge, R&D, and customer service.
CR
Old Apr 30, 2007 | 10:13 PM
1200custom's Avatar
Thanks Cr, Your response helps my decision. I was leaning toward the Airaid till I read your post.
Old Apr 30, 2007 | 10:20 PM
dustindu4's Avatar
9 is not my lucky number.
they all suck, just pick the cheapest one
Old May 1, 2007 | 08:16 AM
Former Vendor
Not a problem at all. The extra money you spend for the C&L system is warranted after you realize the time and effort that went into developing a quality product. I like the racer intake the best myself, but in your situation it requires a tune.
Give me a call when you're ready for an intake and I'll take care of you. Thanks alot!
CR
Tillman Speed
610-497-3711
Old May 1, 2007 | 10:55 AM
LEO_06GT's Avatar
My votes for the K&N Aircharger intake.
Old May 1, 2007 | 11:30 AM
05fordgt's Avatar
CR
CR, I have the Airaid system in my car, and have had it installed for over a year, and NO problems at all. Definitely felt more power out of it, and had 0 episodes of the CEL's. I'm very happy with it. Now, that said, I finally jumped the ship, and got my Bamachips X-Cal II and will be adding the 87 Performance tune to the car as soon as I can (hopefully tomorrow). Now the car will REALLY run great!
Old May 1, 2007 | 11:51 AM
  #40
sodaman's Avatar
Well if I were to buy a no tune intake at this point I would have to say try the c&l with special insert. They have taken the time to make a good intake first, then modify the insert to make the air flow same as factory at the maf point, so as far as functionality, this makes sense to me, more so than changing maf and a jumper harness etc. This is straight forward thinking which should give you straightforward results using stock maf, and no computer changes so much easier to change out etc. I was witness to the item being tested and dynod' it did look like a quality piece and did what it was supposed to do. without a tune. So Just my 2 cents, I think the c&l is the safest no tune bet or possibly air raid since they are basically doing the same thing, size of insert etc to mimic factory air intake air flow.
