Which no tune CAI is better?
I've been trying to find out which one of the CAI's that do not require a tune actually works and delivers what it promises. I've narrowed it down to 3: BBK, Granatelli and C&L with the no tune option. I know that the best way is to get one with a tune but thats not in the cards right now,but I will get a tune eventually. I just want to find out what I can get right now and make sure I won't hurt my engine while but still get some decent power gains. I appreciate any advice I can get, thanks in advance
Go with an Airaid/Roush. This intake has a removable sleeve that makes the MAF area a lot larger (great with a tune). Don’t know much about the BBK or C&L, but can tell you don’t go with a GMS with its reprogrammed MAF. The reason is that when you get a tune you will have to remove their MAF and jumper wire. A lot of money for nothing.
Just my $0.02
Just my $0.02
Been running the GMS set-up for six months, really woke up the engine. No problems, no issues, runs great. I would recommend it, can get a used one for about 200.00 saw it listed in the "for sale" area a month or so ago. Do a search in that thread. All check corral.net and ebay! Good Luck.
For a no tune CAI, I think the GMS is the way to go. I have solid gains that you can really feel, and if you ever want to do more, all you have to do is put you stock MAF back in and get a tune, and realize even more gains. So for me, that makes it a plus, and not a disadvantage as bad monkeys mentions above.
For those that like their “no-tune” GMS intake, ask Doug at Bama what he thinks of them.
Believe me, I did a lot of research before going the route I did and the GMS just does not make dollars and cents if you plane to do a tune in the future.
The age old debate continues... lol. I can only report my own personal experience, and it was positive with the GMS, however, do yourself a favor and get a CAI with tune. You'll ultimately wish that you had and save some money in the process.
Here's my rant concerning the GMS ! for those who don't ever plan on doing a computer re-flash ? I'd definitely rank it as probably the best CAI that doesn't require any re-tuning of the PCM..However for those who plan on tuning upgrades down the road ? the supplied MAF and jumper harness cannot be used with a tuner/programming device in which the tuning files are both written and based exclusively upon the stock MAF settings only ! Therefore you're now stuck with some useless re-calibrated MAF and jumper harness just sitting there gathering dust somewhere in either the basement or garage
The GMS no tune intake has seen AFRs in the 17s up top end for their no tune option. That's MORE than detrementally lean. Just my own personal opinion... the only no-tune I would trust is C&L, end of story. In that situation, it doesn't cost a dime to take out the insert, and run a tune. Just my 2 cents...
I agree with Tillman. I had the GMS and it was runnging m 16's when dyno'd. I had to get dyno tune the GMS. I would recommend that anyone that has the GMS get a dyno check. Just my opinion. You will never know your A/F is off unless it is checked. I never had a engine check light even though it was running in the 16's.
I don't believe there really is a "no tune" CAI.
I went with the K&N CAI because of it being closer to the same cfm as stock (and I got it cheap from another member).
After running it for a couple thousand miles,the computer had the car running rich (12 to 11). I have heard of others who actually tested it finding the same thing.
Just bite the bullet and get a big cfm CAI and a tune and be done with it.
