Neutral safety switch
Old 2/5/12 | 08:19 PM
SilverSkoundrel's Avatar
I remove this or bypass it will it shoot a engine code? And how should I go about it?
Old 2/6/12 | 12:58 AM
houtex's Avatar
It won't throw a code, I don't think. I am curious as to why you'd want to do this, though, it's not a very safe thing to do.
If you tell us it's to install an auto-start, and it's a manual, then please, for the love of your fellow man, or at least your car, don't do it. Some guy did it, and wound up having the dealership 'start' it into a lake when it went in for service.
On the how, not gonna tell you. I don't think it safe, regardless of your reasons. It's there to protect you, everyone else, and the car.
/And that's all I got to say, off the soapbox now.
Old 2/6/12 | 07:31 AM
Just so I don't gotta be in it to start it lol no auto start. I always put my junk in the passenger side and would like to be able to start it from that side as well
Old 2/6/12 | 10:00 AM
Do automatics have this switch? They start right up?
Old 2/6/12 | 10:13 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Automatics do. But its a different design. That's why you can't start it in drive.
Old 2/6/12 | 10:19 AM
Makes since
Old 2/6/12 | 10:21 AM
AlsCobra's Avatar
A Man Just Needs Some....
I'm guessing yours is a manual. Should just be a two wire switch connected to the clutch pedal. Either jump the switch or leave it disconnected. Not sure which way it operates.
Old 2/6/12 | 10:31 AM
Bear Eats King...
Bear ****s Bone
You leave it open if I remember right
Old 2/6/12 | 10:39 AM
AlsCobra's Avatar
You might be right. All it takes is to leave it in gear one time when starting and you may be regretting bypassing it though.
Old 2/6/12 | 10:41 AM
Bear Eats King...
Bear ****s Bone
Got that right. Lot of horror pics online
Old 2/6/12 | 10:45 AM
I'm pretty **** about leaving it in gear/pulling parking brake, so if I **** up then there will be a told you so in order.
Old 2/6/12 | 10:48 AM
skunk21's Avatar
Just like this or atleast that is how it is done on the fox. Make a jumper wire with two spades to plug into the switch...I would advise just like the others against this. You can get a remote starter for manuals that will not allow the car to start if it is gear. bypassing it w/o some kinda safety net isn't going to end well one day jsut like the others stated.
Old 2/6/12 | 10:49 AM
AlsCobra's Avatar
Yep. I put a dodge Dakota into a fence once that had a bad switch. Scared the crap out of me. It should be real easy to do if it is just a two wire switch. Just unplug it and try to start. If it doesn't work, jump the connector.
Old 2/6/12 | 10:57 AM
Well I've had 2 previous cars this was already done to, plus all 5 vehicles I've driven/owned are manual so I'm pretty broken into putting it in neutral to start it
Old 2/6/12 | 10:58 AM
AlsCobra's Avatar
Cool man. Good luck. Let us know how it turns out.
Old 2/6/12 | 11:09 AM
Bear Eats King...
Bear ****s Bone
We know how its gonna work out... he is going to make a back door to his garage
Old 2/6/12 | 11:15 AM
That's not cool man
Old 2/6/12 | 11:16 AM
AlsCobra's Avatar
That's not cool man
But almost inevitable.
Old 2/6/12 | 11:23 AM
Bear Eats King...
Bear ****s Bone
That's not cool man
Just trying to help
K.A.I.N
13
12/26/15 02:29 PM
10/2/15 02:00 PM
Rando
9/30/15 01:28 PM
irobles
1994-2004 V-8
9/20/15 05:30 PM
