Need some help on the pro 5.0 shifter
Old Feb 28, 2007 | 08:14 PM
Bullitt995's Avatar
Hey I just got my new shifter installed and first of all, I LOVE IT. Smoother than the stock one and way shorter throws. Worth every penny. Only thing that's worrying me is that the shifter seems to be too far to the left in the console. It shifts great into every gear and I do have the bushings on the right sides. Can someone take a picture of their pro 5.0 shifter from the top to see if it's the same as mine?
Old Mar 1, 2007 | 10:03 AM
S197 GT's Avatar
3rd Times A Charm
Mine's off to the left too.
Old Mar 1, 2007 | 03:05 PM
dly's Avatar
dly
Is the shifter handle on the right side of the shifter stick???
Old Mar 1, 2007 | 07:45 PM
Bullitt995's Avatar
That was it. I figured it out when the forum was down. The pictures in the instructions show it on the wrong side for some reason. Thanks for your help though!
Old Mar 1, 2007 | 09:42 PM
Jon_Purdy's Avatar
Don't mean to hijack the thread but are you experiencing any vibrations with the Pro 5.0? I have a Roush that I need to replace.
Jon
Old Mar 1, 2007 | 10:50 PM
Bullitt995's Avatar
None, It's rock solid. I even managed to do the install without dropping the driveshaft.
Old Mar 3, 2007 | 09:00 AM
eromzek's Avatar
I don't want to hijack the thread either, but I'm actually in the market for a new shifter (for the spring) and was wondering if you see any downfalls or problems with the pro 5.0. It sounds like pro 5.0 is the favorite around the forum, but I want to make sure I'm doing as much research as I can before taking the dive. I know MGW is coming out with a shifter soon, and I'm debating between the pro 5.0 and that one.
Old Mar 3, 2007 | 09:22 AM
SoFlaBoss's Avatar
The shift lever (what the shift **** screws onto) on the Pro 5.0 is a different thread pitch than stock. The stock/OE shift **** still fits though, because the **** has only a nylon insert, so the threads on the lever just adapt to the stock **** when you screw it on. However, aftermarket shift ***** that are threaded same as stock, e.g. Roush Billet ****, don't fit, unless you force them to fit by cross-threading. As far as I know, the Steeda Tri-Ax comes with a shift lever with the correct thread pitch. I have the Pro 5.0 with the OE ****, and love it. It's just that now I have a new Roush Billet **** (w/grips, P/N 401427) with no place to go. I refuse to force it on and mess up the threading. If I can't find another shift lever or way to fabricate one, I probably have to sell it.
Old Mar 3, 2007 | 09:48 AM
Jon_Purdy's Avatar
Aren't the Tri-Ax and Pro 5.0 identical in appearance and performance?
Jon
Old Mar 3, 2007 | 10:45 AM
SoFlaBoss's Avatar
Jon
Jon, They're identical in performance. However, the thread pitch on their shift levers is different, which I stated above. And, I believe their bushings are slightly different. I met GPStang06, who has the Steeda Tri-Ax, and he said there was a difference in the bushing/assembly at the bottom end of the stick.
Old Mar 3, 2007 | 10:53 AM
Bullitt995's Avatar
Yeah thats probably the only downfall of the 5.0. I had no intention of using an aftermarket **** so it didn't bother me. I seriously couldn't be happier though.
Old Mar 3, 2007 | 02:06 PM
eromzek's Avatar
Anyone happen to know how much shorter the shifts are (% wise) for both the tri-ax and the 5.0? I take it they're the same?
Also, I've heard the 5.0 is a little better longevity wise. I've gathered that the tri-ax has shown history of having rattling and noise problems that the 5.0 doesn't seem to. Just my 2 cents from what I've heard.
Road_Runner
Sep 2, 2024 04:46 PM
Jul 8, 2016 08:53 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
