Need pic of installed MotoBlue Line Lock solenoid.
Old Oct 28, 2006 | 03:44 PM
Keystone's Avatar
Just took all parts out of the box from RPM Outlet and found there are no instructions. The wiring is a no-brainer, but I bought a kit so I wouldn't have to do any of the engineering or bending of (and I always seem to end up crimping) the lines. If it comes with 2 pre-bent lines, then obviously the solenoid needs to go in a very specific location. Can anyone please post of pic if you have one of these installed? I was hoping to put in in tomorrow and RPM is closed unitl Monday.
http://ww.rpmoutlet.com/05gtjet.htm
Old Oct 29, 2006 | 06:34 AM
flounderlipps's Avatar
Hope this helps
Hope this helps
I see your in PA Im in Ventnor NJ if your close you can come take a look
If you need any other pics you can email me flounderlipps@hotmail.com
Old Oct 29, 2006 | 06:42 AM
More
Old Oct 29, 2006 | 07:28 AM
Keystone's Avatar
Yeah, that does. Thanks.
I went back and looked on their web page, and not only did they neglect to send me the instructions, they didn't send the fuse holder, crimp terminals, fasteners, or the wire. I can supply all that other stuff, but what's their deal? They also charged me a $2.00 "UPS surcharge for residential delivery" to my BUSINESS address. Thanks RPM Outlet.
Old Oct 29, 2006 | 08:09 AM
Keystone's Avatar
Flounderlipps, is your car a V6? Or maybe you don't have a cold air kit?
I went out in the garage and the location where you mounted the solenoid is right where the heat shield for my C&L goes.
Attached Thumbnails Need pic of installed MotoBlue Line Lock solenoid.-fender.jpg
Old Oct 29, 2006 | 01:54 PM
Its a V8 but I have a Kenne Bell
Its a V8 but I have a Kenne Bell So the air intake is on the other side
You might have to trim that shroud around the air filter
And you probably have to install the line lock in the same spot
Because the tubing is pre-bent
Attached Thumbnails Need pic of installed MotoBlue Line Lock solenoid.-kenne-004.jpg
Old Oct 29, 2006 | 01:58 PM
Here is a straight down shot
Of the line lock
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
DarrenGT
Aug 19, 2015 08:22 AM
glo106
Aug 11, 2015 08:29 AM
trackpack13gt
Aug 8, 2015 11:23 AM
