Need help with a chevy problem
Old Jan 12, 2008 | 02:08 PM
another 06gt's Avatar
you guys been a great help in the past and i hope you can point me in the right direction.
My 97 suburban cranks but wont start it has the 5.7 i have a chilton manual but therre is no troubleshooting section.
does anyone know where i can get a flow chart of things to check before i have it towed.
Thanks so much for your help I have to take the stang to work and it going to snow on monday i need to get it fixed.
Thanks Again Saverio
Old Jan 12, 2008 | 02:12 PM
DavidM's Avatar
Well one of two things are absent. Spark, or fuel. I'm not familiar with chevy stuff but the basic principles apply. If you have no spark then you have to troubleshoot the possible areas that would cause this. If its fuel then troubleshoot those areas.
Old Jan 12, 2008 | 04:41 PM
Stoenr's Avatar
Fuel pump is dead. got a rubber mallot? have someone bang on the gas tank as you crank er over. Might get it started so you can drive to get it fixed, vs towing.
I could be wrong of course, nothing like over the counter diagnostics, lol.
But they are very common problems in alot of GM's. The suburban is one of them.
Expect to pay 600-900 bucks, delco pumps are not cheap and its a fuel pump module, not just a measley pump.
Old Jan 12, 2008 | 06:12 PM
iT BETTER NOT BE THE FUEL PUMP DUE TO I CHANGED IT 3 TIMES ALREADY THE LAST ONE IS A BOSCH WHICH IS TWO YEARS OLD!!!!!.
dOES ANY ONE KNOW WHERE I CAN GET A FLOW CHART ON WHERE TO TEST AND GET INFO ONSPARK MODULE ANF FUEL MODULES THANKS
Old Jan 12, 2008 | 07:25 PM
Stoenr's Avatar
Lol, see what I mean about a common problem. We've had the best luck using the O.E pump vs an aftermarket tho. Those kinda jobs suck to do it twice.
Old Jan 12, 2008 | 07:51 PM
97svtgoin05gt's Avatar
The problem is two letters: "GM".
Old Jan 12, 2008 | 08:35 PM
theedge67's Avatar
I think the problem lies in the engine compartment. The distributor is in the rear of the engine, and it should be in front. Get that changed asap and your problems will disappear.
Old Jan 12, 2008 | 09:00 PM
f1-cobra's Avatar
Have you changed the fuel filter, it's on the inside of the frame rail under the drivers door. Very easy to change. I used to own a '90 C1500 as a beater and had replaced just about everything on it. My fix for the spark problem was to install a MSD ignition and new plugs and wires. It made the truck run alot better.
Old Jan 12, 2008 | 09:28 PM
69_gt500's Avatar
I knew someone was gonna say that sooner or later .
Rando
Aug 25, 2021 11:12 AM
CiniZter
25
Apr 28, 2016 05:41 PM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
MRGTX
Sep 16, 2015 08:08 AM
