MIL eliminators question
Have an 08 with an offroad h-pipe about to go on, anyone try the earlier '96-04 BBK MIL eliminators for the check engine light? Had a few poeple say these could work, assume the plug-in's are all the same..... before I spend $ on a tuner.
Thx
Thx
Question? Your first mod is an Offroad pipe. What exhaust tail are you hooking it up to. Careful there, a lot of people here have removed that shortly after instal. Get the tuner anyway, you're going to need it for everything else you do.
i called evolution performance out of PA and they told me they dont work on the 08's i have a 08 with the summit racing off road H and runs perfect with light just a lil rich when i get a tune it will be alot better
You can make your own very easily. I tried it and it seems to work on my 05. I had to replace my driver's side rear sensor due to the heater circuit failing. Now I occasionally get a P2272 code. I think I'm going to have to tear it apart and redo the wiring just to make sure it is right. Just search for MIL eliminators on yahoo.
