MIL eliminators question
Old Jun 8, 2008 | 11:35 AM
08 GT/CS's Avatar
Have an 08 with an offroad h-pipe about to go on, anyone try the earlier '96-04 BBK MIL eliminators for the check engine light? Had a few poeple say these could work, assume the plug-in's are all the same..... before I spend $ on a tuner.
Thx
Old Jun 8, 2008 | 11:40 AM
travelers's Avatar
No they don't work. The only thing you need to do is turn off the rear 02s in the tune and your good to go.
Old Jun 8, 2008 | 11:54 AM
FLAstangx3's Avatar
Question? Your first mod is an Offroad pipe. What exhaust tail are you hooking it up to. Careful there, a lot of people here have removed that shortly after instal. Get the tuner anyway, you're going to need it for everything else you do.
Old Jun 8, 2008 | 04:25 PM
polodinks's Avatar
i called evolution performance out of PA and they told me they dont work on the 08's i have a 08 with the summit racing off road H and runs perfect with light just a lil rich when i get a tune it will be alot better
Old Jun 8, 2008 | 04:36 PM
08 GT/CS's Avatar
Thanks guys, guess its light for bit and then get a tune..... **** that's going to add more power I will run the O/R with stock mufflers, no desire for drone.
Old Jun 10, 2008 | 11:44 AM
superman112's Avatar
are they even selling those MIL's anymore.. a friend of mine needs some and a local shop says they are being produced anymore.
Old Jun 13, 2008 | 10:30 PM
mfdengineer's Avatar
You can make your own very easily. I tried it and it seems to work on my 05. I had to replace my driver's side rear sensor due to the heater circuit failing. Now I occasionally get a P2272 code. I think I'm going to have to tear it apart and redo the wiring just to make sure it is right. Just search for MIL eliminators on yahoo.
MustangConvert11
Sep 30, 2015 08:01 PM
Sep 30, 2015 07:02 PM
