Mickey Thompson 3743 or 3743R?
Old Jan 12, 2006 | 12:59 PM
dustindu4's Avatar
9 is not my lucky number.
I want to mount one of these on my stock rims. Mikem did it on his rims with no problems. The ET streets (3743) require tubes which cost another $55 each. The ET street radials (3743R) don't require tubes I dont think. Is there a difference between the two types of tires? Which ones should I get?
Old Jan 12, 2006 | 01:02 PM
dustindu4's Avatar
Also, is there another brand of tire I should consider instead of the Mickey Thompsons?
Old Jan 12, 2006 | 01:09 PM
rhoover2's Avatar
I ran the 3743's last year without a tube on my stock rims and didn't have any problems at all. I think the radials will perform as well as the bias ply's or at least I think they will. Anyway that is what I am going with this year. I would like to hear what others think about this also.
Old Jan 12, 2006 | 01:11 PM
dustindu4's Avatar
They work without a tube?
Tube type for extra sidewall strength, better air retention, and more consistent ET's.
Is it dangerous to run it without a tube?
Old Jan 12, 2006 | 01:14 PM
dustindu4's Avatar
They also say
NOTE: Besides being required for air retention, M/T® Tubes will enhance the reaction time, increase stiffness and reduce sidewall shock and deflection when launching.
Old Jan 12, 2006 | 01:18 PM
dhof303's Avatar
We run the ET streets without tubes, they just will leak out and go low in a few weeks if you don't keep an eye on the pressures. We pretty much just use them on the track and air them up each time we go. And no it isn't dangerous, just inconvenient to some.
dustindu4's Avatar
Anybody use the Nitto 555R? I wonder how it compares to the M/T tires
The Nitto NT-555R Extreme Drag Radial Tire is an exciting addition to the specialty performance radial tire segment of the Nitto Tire Product Line. With the NT-555R Nitto engineers succeeded in designing a DOT approved, drag racing radial tire. Nitto Tire demanded a tire that would outperform all drag racing radial tires, provide impressive control and handling, and still deliver up to 15,000 miles of tread life of normal street-driving use. NT-555R's are manufactured with the original tread depth of 6/32nd's of an inch and are constructed with a specially formulated soft racing tread compound to provide maximum traction. However, this soft and flexible tread will wear much quicker than tread compounds formulated for regular passenger cars. The Nitto NT-555R is designed primarily for competition drag racing.
http://www.nittotire.com/tires_555r.asp
Old Jan 12, 2006 | 01:20 PM
dustindu4's Avatar
Ok I feel better about this now. But what's the difference between the 3743 and 3743R besides one being biasply and the other being belted?
Old Jan 12, 2006 | 01:44 PM
rhoover2's Avatar
I tried the 555R's and they weren't bad but when I changed to the MT's I knocked 4 tenths off of my ET. Could have been the difference between the 17" MT's and the 18" 555R's though. The 17's gave me more of a sidewall to take up some of the shock at launch.
Old Jan 12, 2006 | 01:46 PM
jp's performance's Avatar
i did when the car still had 3.55's and the best 60ft was a 1.87 not bad but the mt radial will be alot better and you can drive them on the street until it rain's and then your in trouble,for the track go with the et streets my best 60ft was 1.57 good luck and see you in april.
Old Jan 12, 2006 | 01:58 PM
don_w's Avatar
If you plan on driving on them (on the roads) to get to the track, I would recommend the radials. They have a little more tread than the ET Streets (see pics below), which is helpful if you encounter a little water along the way. I usually change mine at home, and then drive to the track. I hate trying to fit two tires/wheels and a floor jack in the car, plus then I don't have to leave my street tires/wheels & jack laying around in the pits.
The ET Streets (3743) uses an M5 compound, and the Drag Radials (3743R) use a special R2 compound. Comparatively, the R2 is slightly softer than the M5 (see Mickey Thompson Tech Specs).
And the radials hook plenty well. I know JDM ran as low as 11.60s on the 275/40-17 M/T drag radials.
Old Jan 12, 2006 | 02:24 PM
dustindu4's Avatar
I am getting spare rims so I will be swapping them out at the track. I won't be driving these on the street unless I don't feel like changing them for the ride home. I know the M/Ts are terrible on the rain.
Right now I'm leaning towards the 3743 Biasplies.
Old Jan 12, 2006 | 06:58 PM
169stang's Avatar
I didn't use tubes either. They never really dropped air, that I could tell.
Old Jan 12, 2006 | 08:21 PM
Black3V's Avatar
I run the ET Streets without a tube also and it gives me consistent 1.6 60 ft times where the Nittos would never go under 1.8. I even drive on the ET streets to the track about 40 miles ( not good for tread life) and they are fine as long as I stay clear of water.
Old Jan 12, 2006 | 09:38 PM
dhof303's Avatar
That is the new tire we will be running for Ultra Stang class at FFW this year. I haven't had a chance to put them on the car yet though we did have them mounted already in place of our ET streets. Until this turbo gets tuned we will be frying the street radials (Fuzion) that we originally had put on in place of the factory crap.
Bert
Jul 25, 2015 02:13 PM
dustindu4
Mar 11, 2006 08:37 PM
dustindu4
43
Feb 2, 2006 08:23 AM
dustindu4
35
Dec 29, 2005 11:06 AM
