Lowering spring installation. Difficult?
Old Aug 13, 2005 | 06:40 AM
05STG1's Avatar
Originally posted by biznazion@August 12, 2005, 12:02 PM
Yes - 28¼ inches from ground to fender with about 2 inches of gap between wheel and fender front and rear.
Thanks for the reply. Looks like I might look into bringing the rear down a bit. Im @ 29" in the rear, ground to fender, and 28.25 for the front.
SS-
Old Aug 13, 2005 | 08:23 AM
05RedfireGTVert's Avatar
Originally posted by Herknav@August 10, 2005, 10:52 PM
Word I got from another source says that the rear springs on the Vert are harder due to additional stiffening...
That was probably me. Yes, the rears are not so easy on the convertible because the extra bracing under the rear end prevents the rear axle from dropping enough to slip those springs out. I actually had to get a spring compressor up in there and hand crank it with a crescent wrench till I could pry them out. Pretty painful.
Old Aug 13, 2005 | 08:41 AM
Herknav's Avatar
Yeah, it was you... you caught me.. This the primary reason I am laying off the springs for now... that and I want to see how the pro kit plus works out... and since I am unwilling to be the GP... guess I have to wait...
Old Sep 18, 2005 | 07:57 AM
Wardog 07's Avatar
Anybody have install instructions for a panhard rod (adjustable)?
Can't find anything on SEARCH.
TIA
Tom
Old Sep 18, 2005 | 09:46 AM
wild stray's Avatar
Jack the rear up, unbolt the existing and bolt up the adjustable. No problems encountered here. Don't worry, be happy.
Old Sep 18, 2005 | 10:27 AM
Wardog 07's Avatar
Thanks . . . jack the car up? or jack the diff up?
Old Sep 18, 2005 | 12:01 PM
harrier's Avatar
Originally posted by biznazion@August 11, 2005, 11:30 AM
I think it depends on if the rear axle is really out of center to start with. Apparently some are and some aren't. I lowered the rear of mine about 1" and using a weighted string dropped down from the fender, the bulge of the tire shows about a 1/8" shift to the drivers side. I still have the factory panhard bar.
dittos.
the lower you drop your car, the more pronounced the offset may be. and any offset to the left, if any, will be more pronounced or apparent the wider the tire you use.
i have eibach sportline springs which have more drop to them than the pros. also, i am running 305/25-20 rear tires. my tires are approx. 1/4" inside my rear fender lips. they are dead on centered. i still have the stock panhard rod. it's the luck of the draw if you ask me.
see this link if you want to see a rear end that is way out of wack and the solution:
http://forums.bradbarnett.net/index.php?sh...&hl=panhard+rod
Old Sep 18, 2005 | 12:58 PM
wild stray's Avatar
[quote=Wardog 07,September 18, 2005, 9:30 AM]
Just jack the car up a bit so you can get under it to work.
Paul
Autotooner
Nov 24, 2017 12:42 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
