lower temp thermostat
Has anyone here installed a lower temp thermostat? Is there any power gain with this mod.... since these cars run better when cold? Also is there any problems with a lower temp themostat, do you need to retune ? Thanks
has any one tried that water wetter stuff???
http://store.summitracing.com/partde...5&autoview=sku
I run a 160 Tstat, and all that really does is allow coolant circulation to start a little sooner. It won't cause the engine to run below the 180-200 range. It also won't add any power.
And yes, I also use Water Wetter.
robjh22
9/8/15 12:31 PM
