lower temp thermostat
Old Aug 30, 2006 | 07:27 PM
hmc610's Avatar
Has anyone here installed a lower temp thermostat? Is there any power gain with this mod.... since these cars run better when cold? Also is there any problems with a lower temp themostat, do you need to retune ? Thanks
Old Aug 30, 2006 | 07:30 PM
has any one tried that water wetter stuff???
http://store.summitracing.com/partde...5&autoview=sku
Old Aug 30, 2006 | 07:55 PM
karman's Avatar
Our local tuner says this,"I would personally not recommend going with a 160 degree T-stat. Your engine was designed to run around 200 deg. Running it down to 180 is ok but below that it will actually advance the ring wear on your pistons. Your piston clearances, bearings, etc. are designed for 180-200 degree operation, below that you will cause engine wear earlier. I've seen pics of motors that were run at 160 degrees for a long time and the pistons were scuffed, rings worn, and had carbon build-up on the piston tops. You will not gain any more power running at 160 anyway. Remember, you efi doesn't even go into closed loop until 150 degrees, below that it's considered a "cold" start."
Old Aug 30, 2006 | 08:02 PM
don_w's Avatar
I run a 160 Tstat, and all that really does is allow coolant circulation to start a little sooner. It won't cause the engine to run below the 180-200 range. It also won't add any power.
And yes, I also use Water Wetter.
Old Aug 30, 2006 | 08:21 PM
94tbird's Avatar
i also have a 160 tstat and i also use water wetter in both the S/C coolant and the engine coolant
Old Aug 31, 2006 | 08:54 AM
dustindu4's Avatar
9 is not my lucky number.
I have a 160 stat for sale $20 shipped, PM me.
Old Aug 31, 2006 | 04:18 PM
karman's Avatar
So, is that because of Pete's advice?
robjh22
'10-14 Exterior Modifications
Oct 9, 2015 02:49 PM
Evil_Capri
Sep 25, 2015 12:56 PM
robjh22
Sep 8, 2015 12:31 PM
