lower control arms for street use only
Old Jan 11, 2011 | 07:14 AM
gpp's Avatar
gpp
are the aftermarket lca worth it it for street driven only cars?will it help a tire spinning problem on a 500 hp car when you floor it at 25 to 35 mph,used with street drag radials?
Old Jan 11, 2011 | 08:24 AM
69Mach1-409's Avatar
CHE Adj's LCA with the Poly/Delrin on both ends sense she was 6months old.. I cannot remember what it's like without them.. though I now have the full CHE Adj suspension (with bracing & HD mounts) and I can still spin the 285/40ZR18 Goodyear Supercar F1's at Hwy speeds...
I think I'm going to upgrade to a 305 Nitto or MT Street Radial this summer.
Old Jan 11, 2011 | 07:30 PM
SONICBOOST's Avatar
I had lower control arms installed the same time as my blower and the suspension definently felt more smooth and planted after the LCA's were installed...
Old Jan 13, 2011 | 10:57 AM
sam strano's Avatar
My first question... Do you have wheelhop? If yes, then LCA changes will help. If no, then really not worth the change.
There are many, many options. I carry an few different brands, and each makes multiple LCA's that can be used for street use. Each has pro's and con's in certain areas.
yabutt
Oct 23, 2015 01:05 PM
Evil_Capri
Sep 25, 2015 12:56 PM
