KB@17psi makes MAD TORQUE!!!
Old Jun 27, 2007 | 11:00 PM
SilverPOISON's Avatar
www.racersedgetuning.com did a race tune today on my car. The numbers are 525/555, on a low compression engine. The car is an animal. I am very happy with the outcome, I did some upgrades to my fuel system and to my exhaust. RET did an awsome job!!!
As soon as Greg has some free time (2 day old baby) we are taking the car to the track, everything with the exception off the 3 inch studs is ready.
Video
Old Jun 27, 2007 | 11:13 PM
GottaHaveIt's Avatar
Nice Now do behave !
Old Jun 27, 2007 | 11:18 PM
StangPower05's Avatar
Wow! Thats gunna be one hell of a monster!! Cant wait to see what its gunna do in the 1/4!!
Old Jun 28, 2007 | 12:26 AM
Error404's Avatar
sweet!! :-)
Old Jun 28, 2007 | 05:22 AM
dustindu4's Avatar
9 is not my lucky number.
Should be low 11s or a high 10 if you're lucky
I hope you have a cage because you won't be making many passes
Old Jun 28, 2007 | 08:25 AM
RobK's Avatar
Any details on your built bottom end? You're in the neighborhood of my targeted range with a KB. Keep us updated regarding how it holds up.
Old Jun 28, 2007 | 09:13 AM
Built by www.spankintime.com
JE Custom forged Pistoms
Cobra Crank
4340 H-beam Rod
Bearings (Rod/Main)
Gaskets (heads, timing cover, real seal)
Head studs
KB 8-rib pulley set-up
Stock heads with upgraded springs
Stock Cams
it is a low compression engine, that will allow me to trow a lot of boost to it,
Old Jun 28, 2007 | 10:14 AM
don_w's Avatar
Congrats Eduardo! Sounds like it should be a beast. What else have you done to the car to make sure it hooks up?
I don't understand this one... you should just go whether he can or not. Dyno numbers are nice... but I want to see the track numbers!!
Old Jun 28, 2007 | 11:59 AM
I've done this + my bogarts with skinnies and slick s
I rather go whenever he can, I might need to do some adjustments and he can be very usefull.
Old Jun 28, 2007 | 12:57 PM
RobK's Avatar
Cobra Crank
4340 H-beam Rod
Bearings (Rod/Main)
Head studs
Stock Cams
Thanks for the info! This is about the 10th time I've seen someone list a Cobra crank. Do you mean the OEM piece from the SN95 Cobra? Forgive me, I'm a BMW guy feeling my way through the dark here. I haven't had a Stang since my '97 Cobra.
Old Jun 28, 2007 | 01:07 PM
Spankin new OEM cobra crank!!!
Old Jun 28, 2007 | 01:12 PM
don_w's Avatar
I've done this + my bogarts with skinnies and slicks
Well alrighty then... that looks like it ought to work!
+1... same here.
Old Jun 28, 2007 | 04:41 PM
Bullitt995's Avatar
525 at 17 lbs? Must not be running much timing.
Old Jun 28, 2007 | 09:45 PM
less than 20. The day was very hot too. 93 degrees....California baby!!
Old Jun 29, 2007 | 08:49 AM
Bullitt995's Avatar
Good plan, keeps it nice and safe.
Uofmrampage
Aug 2, 2022 02:55 PM
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
MRGTX
Sep 16, 2015 08:08 AM
Evil_Capri
Sep 11, 2015 08:39 AM
