THE JLT FILTER FALLING OFF PROBLEM...
#41
Originally posted by 05stangkc@June 14, 2005, 6:25 PM
If This Clamp don't Hold it on Nothing will!
[attachmentid=24493][attachmentid=24494]
#42
I have to agree with 2MFF. The more you tighten it down the more likely it will squeeze off or deform your pipe with added engine heat.
I personally found that making the pipe end a rough surface with sand paper and cutting grooves with a dremel seemed to work great; however, I had no idea where the deforming of the pipe came into play (except heat of course).
Cheers-Jay
Cheers-Jay
#43
The Analog Admin!
Received 3,204 Likes
The Spring Loaded Clamp allows for expansion and contraction without overtightening. These are used on turbo pipes with Boost Pressure. A regular clamp is more likely to get expanded and then become loose. The spring maintains a constant pressure and will not become loose.
BTMO.
kc
BTMO.
kc
#44
Good looking clamp....MY JLT falls off from time to time as well and is really annoying.....I'll attempt some of the fixes mentioned above and see what I can get from them....
