Interior of the car is cooler now.
My car was getting a lot of heat from the stock cats. I drive with the windows down all of the time, but I have had to use the A/C a few times in slow traffic because of the heat generated off the stock cats.
Not a problem now. These competition cats are about 1/5 of the size of stock, not to mention a lot lighter.
comes out alot better and has more fluff to it... you should try it...
hawgman
Changing out the cats CURED mine.
The stock cats are as long as my thigh, and they get VERY hot. They are located just under the center consul. A boot on the parking brake would keep some of the heat bottled up, but not all.
I have the Bassani comp cats and my center console is always cool. Also, you are correct that they are much lighter. I would say b/w the two of them you save easily 20-30 lbs. I held the factory H pipe with cats and man that thing was heavy.
Look at the size difference:
http://franksperformance.com/Forums/index....ry&cmd=si&img=7
Anyone know where you can order JUST the cats (and surrounding pipes), i.e., WITHOUT the X-pipe. I ordered and installed the X-pipe keeping the stock cats, but think I'd like to replace them at some point with the full bassani cats. Does this make sense...?
sarnold58
Jun 9, 2019 02:22 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
