Interior of the car is cooler now.
Old Jul 3, 2005 | 08:34 PM
38special's Avatar
My car was getting a lot of heat from the stock cats. I drive with the windows down all of the time, but I have had to use the A/C a few times in slow traffic because of the heat generated off the stock cats.
Not a problem now. These competition cats are about 1/5 of the size of stock, not to mention a lot lighter.
Old Jul 3, 2005 | 08:50 PM
Burke0011's Avatar
Big Falken Tires
Ah-HA.... maybe that's where most of the extra heat these stinkers put out comes from.......
Old Jul 3, 2005 | 09:12 PM
38special's Avatar
I was even thinking of getting a parking brake boot to help solve the problem, and I may still do that, but now it is not so urgent.
Old Jul 3, 2005 | 09:32 PM
SixtySix's Avatar
Out here in the desert I wouldn't even notice
Old Jul 3, 2005 | 09:35 PM
38special's Avatar
In the desert you are a horse with no name sixty six.
Old Jul 3, 2005 | 10:48 PM
SixtySix's Avatar
La La.. La..... La... La La.. La La
Old Jul 4, 2005 | 04:45 AM
WERKED 66's Avatar
are you guys talking about the heat in the floorboard`s...? if so it has to be the only car where i have seen this much heat coming off of.... thought i was me... or not enough insulation...
Old Jul 4, 2005 | 04:49 AM
38special's Avatar
WERKED 66
Yes, the heat from the floorboards. Until I changed out the cats, I thought there was a blast furnace under there.
Old Jul 4, 2005 | 07:10 AM
WERKED 66's Avatar
yea, i joke all the time about it... how you can bake a cake...
Old Jul 6, 2005 | 04:58 AM
38special's Avatar
Never baked a cake, just my bacon.
Old Jul 6, 2005 | 05:15 AM
WERKED 66's Avatar
comes out alot better and has more fluff to it... you should try it...
Old Jul 6, 2005 | 06:53 AM
hawgman's Avatar
I have quite a bit of heat coming from the center console. I have had Ford look to see if any heat shields might be missing there is so much. Hummm...wonder if this would cure the issue?
Old Jul 6, 2005 | 06:57 AM
38special's Avatar
hawgman
Changing out the cats CURED mine.
The stock cats are as long as my thigh, and they get VERY hot. They are located just under the center consul. A boot on the parking brake would keep some of the heat bottled up, but not all.
Old Jul 6, 2005 | 07:03 AM
I8URVTEC's Avatar
I have the Bassani comp cats and my center console is always cool. Also, you are correct that they are much lighter. I would say b/w the two of them you save easily 20-30 lbs. I held the factory H pipe with cats and man that thing was heavy.
Look at the size difference:
http://franksperformance.com/Forums/index....ry&cmd=si&img=7
Old Jul 6, 2005 | 03:06 PM
ILikeBond's Avatar
Anyone know where you can order JUST the cats (and surrounding pipes), i.e., WITHOUT the X-pipe. I ordered and installed the X-pipe keeping the stock cats, but think I'd like to replace them at some point with the full bassani cats. Does this make sense...?
Ecostang
Nov 3, 2022 08:50 PM
sarnold58
Jun 9, 2019 02:22 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
chadh92
Jul 29, 2015 06:56 AM
GT40 2
Jul 7, 2015 12:26 PM
