Insulation
Old Jun 26, 2005 | 07:35 PM
softbatch's Avatar
I talk to cones.
Has anyone taken the insulation out of their GTs to improve the weight? Could this be a hundred or more pounds off the car? Also how bad is the noise levels with the insulation out?
Just trying to figure out some weight saveing tactics that don't mess with the cars looks.
Old Jun 27, 2005 | 12:45 AM
Mongoose's Avatar
Take out three seats, the spare and jack plus whats left in the trunk. Hood insulation could go too. I bet it would be noisy. You could sure hear that motor.
Old Jun 27, 2005 | 07:38 AM
WERKED 66's Avatar
even with all that stuff i still hear the mighty v8 screaming..... as far as how much weight will it save by pulling it out... prob... about 100 pounds if that much .. depending what type of material it is.....
Old Jun 27, 2005 | 01:01 PM
kellera6's Avatar
I took off all the panels from the doors back and there is hardly an insulation at all! It might save you about 3 pounds! No kidding!
Old Jun 27, 2005 | 01:50 PM
softbatch's Avatar
I talk to cones.
There usually isn't much insulation behind the panels I am talking about insulation and sound deadening underneath the carpet.
Old Jun 27, 2005 | 03:55 PM
169stang's Avatar
I've heard somewhere that all the carpet padding/insulation and the insulation throughout the car totals up about 45lbs. Your weight reduction will really happen when you remove the a/c, passenger seat, electric window motors. One way to drop 26lbs from the front is to remove the sway bar and radiator support, then replace all that with BMR's radiator/swaybar delete bar.
http://www.bmrfabrication.com/05Mustang/RS002.jpg
http://www.bmrfabrication.com/2005Mustang.htm
Old Jun 27, 2005 | 06:02 PM
softbatch's Avatar
I talk to cones.
Doesn't removing the swaybar hurt handling/cornering? I see prolly not worth the effort for the weight reduction unless your really serious.
Old Jun 27, 2005 | 06:12 PM
169stang's Avatar
There's not much cornering on a 1/4 mile track! It's obviously not for everyone. You asked a general question and I answered.
Old Jun 27, 2005 | 06:18 PM
softbatch's Avatar
I talk to cones.
Lol, yeah i know i was vague, I want to do a little of both so I am going to keep the swaybar
Old Jun 28, 2005 | 08:28 AM
Idrvadodgstr8us's Avatar
Ford spends millions of dollars on engineering...they know these cars in and out. The little bit you save in weight from taking everything out is only going to make the car noisy and reveal squeaks and rattles. Have fun though
Old Jun 28, 2005 | 09:40 AM
169stang's Avatar
Yes they do, but they engineer these cars for daily driving. He's looking for weight reduction for racing applications.
Old Jun 28, 2005 | 09:52 AM
exactly my point...the couple of pounds you save are not worth compromising the inegrity of the vehicle...you are not pro stock...if you want power get a blower or nitrous
Old Jun 28, 2005 | 10:00 AM
softbatch's Avatar
I talk to cones.
I doubt that insulation will do anything to compromise the integrity of the vehicle in a safety sense. There would be the problem of extra noise and heat coming through the floor of the vehicle. My car will be a daily driver but I didn't buy the car for comfort I bought it to have fun.
I am not sure whether I will go the rout of removing any of the sound deadening or insulation but just wanted to get opinions and experiences on the subject. I think I will do further research hopefully with racers and ford engineers to find out the actual weight savings and cons of the removal.
In Summary I probably won't end up doing it for at least a while when the car becomes less of a daily driver and more about having fun in autocross and speed contests.
Old Jun 28, 2005 | 10:06 AM
i didnt say anything about safety...the material is in place for a reason...most likely for sound. The best thing to do is to go to shows and talk with others, perhaps ford mustang team members....this will tell you exactly whats going on...dont do things just because...it will get you in a lot of trouble...learn why its there and the compromise that will result due to its removal
SD CALSPCL
Ecoboost
Nov 16, 2015 11:20 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
BarrySVT
Nov 30, 2006 03:28 AM
metroplex
Oct 29, 2006 12:00 AM
