Installing lower trailing arms from steeda/BMR
Old Apr 17, 2007 | 10:23 AM
  #41
scramblr's Avatar
Originally Posted by max2000jp
The oem control arms on a stock car are level. I don't know how lowering your car made them level??? From the looks of the pics above, you should be running the top setting. You want the control arms to be level.
We'll just agree to disagree. One of the reasons for the terrible wheelhop on these cars, aside from the crappy bushings, is the LCAs are level to the ground. I agree with you that after lowering my car 1.5" the BMR LCAs pointed slightly up, I mispoke there. Hence the relo brakets. If the LCAs are level to the ground, it's pushing the axle towards the rear vs down where you want the power to go...to the tires, not the rear, hence my lower setting. But of course, it all depends on what the person wants out of their car. I want the maximum traction possible for the track. DD would not require that and relo brackets would not necessarily be required.
Old Apr 17, 2007 | 12:04 PM
  #42
max2000jp's Avatar
The wheelhop in this car is because of the soft rubber bushings and stamped steel material. My wheel hop was cured when I installed an UCA and lower control arm. I didn't change anything in terms of suspension geometry. Email Steeda and see what they say in regards to the position of where the lca's should sit
Old Apr 18, 2007 | 04:21 PM
  #43
NewEdgePerf's Avatar
Ingalls Engineering also offers adjustable, lower control arms, adjustable panhard bar for the rear of your S197 as well as a rear shock brace, double front stress bar, and its engine torque damper set-up known as The Stiffy.
More choices for you!
Tony D
Old Apr 18, 2007 | 05:22 PM
  #44
don_w's Avatar
I've never ever had any wheel hop, regardless of my power levels or suspension components.
Old Apr 18, 2007 | 05:44 PM
  #45
max2000jp's Avatar
I don't know what to tell you. My car wheel hopped at the track and on the street with the OEM control arms.
Old Apr 18, 2007 | 08:32 PM
  #46
scramblr's Avatar
Yeah, I noticed mine within the first couple of days of owning the car.
Old Apr 19, 2007 | 10:34 AM
  #47
Rudiepoo1's Avatar
Noticed wheel hop as well when accelerating over severe bumps.
SpeedyJoe
18
Aug 23, 2015 02:42 PM
SMBJoshy
Aug 16, 2015 02:48 PM
Big-D
Jul 27, 2015 11:24 AM
killaz05
Jul 24, 2015 08:49 AM
