Install only an X pipe?
I figured this would be a good way to turn up the volume a bit on the stock exhaust, and maybe add a few horsepower.
Has anyone done this and figured out the gains?
If the x-pipe has cats it won't be a ton louder, but if you are looking for a modest increase in volume with a nice throaty grawl, go for it. Magnaflow and Bassani will be your best bet.
Well, Ford did do a good job with the mandrel bending of the stock h-pipe. Although, the high flow comp cats will have higher flow and the crossover will result in better exhaust scavenging and evacuation. So that is how these x-pipes can pic up such decent gains over stock. Mind you that they are not huge HP gains but they are quite noticeable at WOT.
Originally posted by 06TripleBlackGT@August 1, 2005, 7:29 PM
Does it really pick up that much HP since the factory intermediate pipe is now also an X-pipe design and is mandrel bent 2.5" also??
If you can go no cats, do it. I currently have the MAK performance Offroad X-pipe with stock mufflers, and it sounds mean, much louder and deeper than before, but not too loud going down the freeway. I haven't been to the dyno, but in talking to the owner of MAK and other owners of the pipe, they say about 12-17 rwhp can be gained from the pipe depending on the application. I will suggest a custom tune with it though. It is not required, but i seemed to have benefited from the tune, as the car tends to run rich with the pipe on, and needs to be tweaked a bit. Also, the pipe is only 199 bucks, and really easy to install, i love it so far (about 2000 miles).
Hope that helps.
Hope that helps.
MM & FF magazine is doing an article next month on x-pipes. Mustang Exhaust did an article and got 1 HP peak with an x-pipe. It did much better at high rpm. If its no cats 10-15 HP, high flow cats 5-7 HP, stock cats 3-4 HP.
3 Cheers for the MAK Off road. Mine has been great, once I solved a few installation gremlins(rattles). The performance gains are there throughout the rpm range, but it's most noticeable up top. Sounds great, but is a bit raspy with the OEM mufflers. X-pipes in general sound raspy, but I knew this from the get go. Can't go wrong with the price and performance gains!
From what I've been able to glean, there is a trade-off between H and X pipes. X pipes will produce more hp, where H pipes produce more torque. The sound is different as well. An H pipe also sounds more like a vintage muscle car (my 351W-4V had a stock H-pipe).
I'm an H-pipe fan, but I like gut wrenching torque and deep rumbly exhausts. If you want a high hp screamer, the X-pipe is probably your cup of tea.
Originally posted by eighty6gt@August 9, 2005, 8:15 PM
Isn't it "Mac"?
I've decided to sock money away for some JBA LT's and their catted H. w00t!!!
Isn't it "Mac"?
No, the product that we are talking about is a company from FL called MAK Performance. MAC is a different company. The one we have is www.makperformance.com
A little off topic but it was mentioned how great the supposedly mandrel bent stock exhaust is. I just installed SLP LM's today and was very surprised to find a not so mandrel bent section in my exhaust. At one point (just before where the axle-back section starts) the pipes are crimped down to about half their normal size for clearance.
Want to free up airflow? Replace that section.
9/10/15 12:44 PM
