Install only an X pipe?
Old Aug 1, 2005 | 05:33 PM
eighty6gt's Avatar
I figured this would be a good way to turn up the volume a bit on the stock exhaust, and maybe add a few horsepower.
Has anyone done this and figured out the gains?
Old Aug 1, 2005 | 07:23 PM
ryan1112's Avatar
If the x-pipe has cats it won't be a ton louder, but if you are looking for a modest increase in volume with a nice throaty grawl, go for it. Magnaflow and Bassani will be your best bet.
Old Aug 1, 2005 | 07:26 PM
06TripleBlackGT's Avatar
Does it really pick up that much HP since the factory intermediate pipe is now also an X-pipe design and is mandrel bent 2.5" also??
Old Aug 1, 2005 | 07:41 PM
ryan1112's Avatar
Well, Ford did do a good job with the mandrel bending of the stock h-pipe. Although, the high flow comp cats will have higher flow and the crossover will result in better exhaust scavenging and evacuation. So that is how these x-pipes can pic up such decent gains over stock. Mind you that they are not huge HP gains but they are quite noticeable at WOT.
Old Aug 2, 2005 | 10:32 AM
Kluski's Avatar
Stock is an "H" pipe. Rumor has it that you can gain about 15hp from an x-pipe. I plan on getting just an x-pipe at first. Especially since the mufflers don't offer any hp gains.
Old Aug 2, 2005 | 11:42 AM
05mineralgrey's Avatar
If you can go no cats, do it. I currently have the MAK performance Offroad X-pipe with stock mufflers, and it sounds mean, much louder and deeper than before, but not too loud going down the freeway. I haven't been to the dyno, but in talking to the owner of MAK and other owners of the pipe, they say about 12-17 rwhp can be gained from the pipe depending on the application. I will suggest a custom tune with it though. It is not required, but i seemed to have benefited from the tune, as the car tends to run rich with the pipe on, and needs to be tweaked a bit. Also, the pipe is only 199 bucks, and really easy to install, i love it so far (about 2000 miles).
Hope that helps.
Old Aug 3, 2005 | 09:48 PM
Fman67's Avatar
I did the offroad Mak x-pipe. Makes stock exhaust much louder...but still crising is quiet. A bit raspy in note. Noticeable performasnce gain(SOTP)
Old Aug 4, 2005 | 01:29 AM
1trickpony's Avatar
MM & FF magazine is doing an article next month on x-pipes. Mustang Exhaust did an article and got 1 HP peak with an x-pipe. It did much better at high rpm. If its no cats 10-15 HP, high flow cats 5-7 HP, stock cats 3-4 HP.
Old Aug 4, 2005 | 08:23 AM
max2000jp's Avatar
3 Cheers for the MAK Off road. Mine has been great, once I solved a few installation gremlins(rattles). The performance gains are there throughout the rpm range, but it's most noticeable up top. Sounds great, but is a bit raspy with the OEM mufflers. X-pipes in general sound raspy, but I knew this from the get go. Can't go wrong with the price and performance gains!
Old Aug 9, 2005 | 09:03 PM
rocketism's Avatar
Just wondering if anyone is having the check engine light come on with the off road x pipes?
Old Aug 9, 2005 | 09:12 PM
eighty6gt's Avatar
Isn't it "Mac"?
I've decided to sock money away for some JBA LT's and their catted H. w00t!!!
Old Aug 9, 2005 | 10:17 PM
Blue Knight's Avatar
From what I've been able to glean, there is a trade-off between H and X pipes. X pipes will produce more hp, where H pipes produce more torque. The sound is different as well. An H pipe also sounds more like a vintage muscle car (my 351W-4V had a stock H-pipe).
I'm an H-pipe fan, but I like gut wrenching torque and deep rumbly exhausts. If you want a high hp screamer, the X-pipe is probably your cup of tea.
Old Aug 9, 2005 | 10:33 PM
Originally posted by eighty6gt@August 9, 2005, 8:15 PM
Isn't it "Mac"?
No, the product that we are talking about is a company from FL called MAK Performance. MAC is a different company. The one we have is www.makperformance.com
Old Aug 10, 2005 | 01:13 AM
StangNut's Avatar
A little off topic but it was mentioned how great the supposedly mandrel bent stock exhaust is. I just installed SLP LM's today and was very surprised to find a not so mandrel bent section in my exhaust. At one point (just before where the axle-back section starts) the pipes are crimped down to about half their normal size for clearance.
Want to free up airflow? Replace that section.
FromZto5
Sep 30, 2015 05:28 AM
ccc
Sep 16, 2015 09:45 PM
Bryanh24
Sep 16, 2015 08:31 PM
Sep 10, 2015 12:44 PM
SMOKE46
Sep 6, 2015 09:40 PM
