I think I figured out why my 1/4 times stink
Old Sep 18, 2005 | 10:42 PM
dustindu4's Avatar
9 is not my lucky number.
Last Wednesday I went up to New England Dragway and met up with George (Blazing Saddles). I made 4 runs, all about 20-30 minutes apart and did 14.471@98.33, 14.675@98.67, 14.477@95.99, 14.479@98.39. Pretty consistent right?
Then I parked the car and let it sit for about an hour and a half with the hood open. When I came back the engine was dead cold. I got back in line and pulled the best run of my life at 14.109@101.13. I did nothing different than what I usually do. I did the same burnout and launched the same way as always.
I guess the key is keeping the engine as cold as possible. Now I know why George put in that electric water pump. Engine temperature is key. These cars just don't cool down fast enough.
Right after I did this great run my engine was super hot and I could barely touch my K&N intake. I got back in line to race George within 15 minutes of my last run. My engine choked on launch, suffering from the "hesistation after deceleration" BS everyone talks about. I did a 15.366@91.86. I am suspecting that the "hesistation after deceleration" is caused by hot engines choking on hot air inside the engine compartment.
What do you guys think?
Old Sep 18, 2005 | 10:47 PM
Cleveland's Avatar
Heat Soak is what your engine is experiencing. It can be seen during long dyno sessions and drag duty. The '05+ will always be known for this above all other issues me thinks.
The trick is to bring a cooler with packets of ice for your intake, it helps a ton between runs with hot outside temperatures.
-Dan
Old Sep 18, 2005 | 11:06 PM
S197 GT's Avatar
3rd Times A Charm
My best time so far is 14.0 with just flowmasters. Stock air box and all.
Old Sep 18, 2005 | 11:12 PM
don_w's Avatar
Heat soak is definitely a problem. But, from my experience, I can "hot lap" 3 or 4 runs, and see about drop off of maybe .01 - .03 per run. But, if it sets for 20-30 minutes or so, it cools off pretty well (at night, anyway). And yes, I gotta get me an electric pump, too!!
BTW, on your last run, did you have TCS turned off? Sounds like maybe it wasn't.
Old Sep 18, 2005 | 11:15 PM
dustindu4's Avatar
yeah it was off
Old Sep 18, 2005 | 11:33 PM
don_w's Avatar
Originally posted by dustindu4@September 18, 2005, 10:18 PM
yeah it was off
I would be extremely surprised if heat soak caused you to drop off by almost a full second. I sometimes make as many as 6-7 passes in an hour, and have never seen ETs drop by more than a tenth or two.... from the first pass to the last one.
Old Sep 19, 2005 | 01:05 AM
dustindu4's Avatar
I'm almost positive it was off
Old Sep 19, 2005 | 06:05 AM
bigaloz's Avatar
I did about 5 runs in an hour, and stayed between 13.7 and 13.8 at 102 to 103 mph, and it's an automatic.
Old Sep 19, 2005 | 08:16 AM
ryan1112's Avatar
If you are on stock tires, don't do a burn out. Just drive around the water. If you get some semi-racing tires or slicks, then do burnouts.
My times when down when is stopped doing them.
Old Sep 19, 2005 | 02:35 PM
dekujala's Avatar
I never thought about the heat myself, could explain why both times I've gone to the strip so far I've got my best time on my first run. Its about a 30-45 minute ride to the strip from my house so the car is nice and hot when I get there. I will have to let it cool down and see if I can shave a few tenths off my time.
Old Sep 19, 2005 | 03:42 PM
jlb's Avatar
jlb
Does anybody have 1/8 times?
Old Sep 19, 2005 | 04:15 PM
don_w's Avatar
I run almost exclusively at 1/8-mi tracks... best run so far for me is 8.811.
Old Sep 19, 2005 | 04:59 PM
mikem's Avatar
1/8 mile............8.14@84.71
Old Sep 19, 2005 | 05:10 PM
jlb's Avatar
jlb
8.14...wow! That's quick. Very quick. Have you ever run it without the MTs? Auto or stick?
Old Sep 19, 2005 | 05:39 PM
don_w's Avatar
Originally posted by Blazing Saddles@September 19, 2005, 4:38 PM
It's best to leave the line at 175-180 degrees.
Wouldn't you be going the wrong direction then?
Old Sep 19, 2005 | 08:28 PM
don_w's Avatar
Originally posted by Blazing Saddles@September 19, 2005, 4:50 PM
Just flip your rearend over and you'll have 5 gears in reverse.
:worship: :worship: :worship:
Last1
Aug 21, 2015 10:53 AM
dohc97
17
Aug 14, 2015 07:12 PM
glo106
Aug 11, 2015 08:29 AM
Beavis9000
Aug 10, 2015 12:16 PM
chadh92
Jul 29, 2015 06:56 AM
