I have a problem
I have a problem
So I decided yesturday to install my BMR LCA relocation Brackets and adjustable panhard bar.
When i took it for a test drive it seemed that when I would brake, the rearend would jut left, making me have to compensate with the steering wheel. Its has gotten worse as I keep driving the car. I have made sure all the bolts were torqued down right and that the bushings were greased.
Any suggestions?
Any suggestions?
"rearend would jut left"
Are you saying that your rearend is lifting or is it pulling to the left? It might be that you don't have the rear wheels centered after installing the panhard bar.
I mean it is kicking out. When I press down on the brake firmly, the rearend seems to slide left so i have to correct the steering. It only does this when i apply firm pressure on the brakes. The rear wheels are centered and the jam nuts have locktite blue on them as well. So idk.
Rando
8/25/21 11:12 AM
