How do i run a different maf
Old Nov 7, 2006 | 01:21 PM
neil07gt's Avatar
What would i need to run a MAF that was made for another type of car in my mustang GT? The other MAF is a calibrated for a different size injector. It will obvious have a different transfer function.
http://www.jdsperformance.com/index....nlist&inmake=0
Old Nov 7, 2006 | 03:40 PM
karman's Avatar
WHY?
Old Nov 7, 2006 | 04:06 PM
neil07gt's Avatar
Originally Posted by karman
WHY?
Suppose I don't want to reflash my ECU, but want a larger MAF. I was only wondering what it would take to retrofit a different MAF into an 05-07 mustang. I'm not saying that i want to do it. But, it would be nice to know how all of this fits together and generate some technical discussion.
For example: (i'm using made-up numbers here) If i took an MAF that was calibrated for an LS1 with 70lb injectors and put it in a mustang that had 39lb injectors, would i have to cut the voltage from the MAF by ~50%?
Old Nov 7, 2006 | 04:14 PM
Doug@C&L's Avatar
To do it properly you would need to recalibrate the PCM using the MAF transfer tables and the injector settings. If not then the Load rating in the PCM wouldn't be correct for the application and if your load value is off then your timing and fuel tables will be off too.
Thanks, Doug.
Old Nov 7, 2006 | 05:06 PM
karman's Avatar
Thanks, Doug.
Sounds a lot harder than a reflash of the ECU.
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 30, 2015 07:02 PM
