How Big Of A Tire!
Old Sep 27, 2007 | 10:36 PM
StangPower05's Avatar
How Big Of A Tire!
How big of a tire could i possibly go,safely, on the FORD 18' Polished Alum. Bullitts? Im looking to go wider on the rear 2 tires. Seeing as they come stock with 235/50/r18. I would like for the tire not to bulge so what would be my best bet. Any info is greatly appriciated.
Old Sep 27, 2007 | 11:24 PM
antdog's Avatar
http://forums.bradbarnett.net/showth...ight=tire+size
Old Sep 28, 2007 | 01:26 PM
Phorty's Avatar
255/45/18's are a perfect fit at all four corners. If you really wanted to a 275/40 would fit but probably would bulge a bit.
Old Sep 28, 2007 | 01:31 PM
I was thinking of keeping the stock 235s on the fronts, and going 275s out back. This setup would not hurt anything would it? Also, would the lit bit of a bulge that the 275s would create look stupid or would it look decent??
Old Sep 28, 2007 | 01:37 PM
Twisted's Avatar
If it’s a 9” wide wheel you can safely run - 275/45/18’s to 275/35/18’s
Old Sep 28, 2007 | 03:41 PM
Originally Posted by Twisted
If it’s a 9†wide wheel you can safely run - 275/45/18’s to 275/35/18’s
The rims size of the stock 18' rims are 18x8.5. Would it be safe to run a 275 out back?
Old Sep 28, 2007 | 11:20 PM
Twisted's Avatar
It shouldn't be an issue I have a local friend that runs 275’s on his factory bullits and has for over a year now.
To get the tread to hit the road correctly you may need to adjust the tire pressure a bit so it wears evenly across the tread.
Old Sep 29, 2007 | 08:30 AM
Ok, thanks for the info.
Old Sep 29, 2007 | 08:52 AM
Phorty's Avatar
If you do this, I would go with a 275/45, not 275/40. The latter will be smaller in diameter than your fronts and would look goofy. It's better to have the backs being a bit bigger than the other way around.
14BlackGT
18
Mar 10, 2017 04:13 PM
wannabe
Sep 23, 2015 05:36 AM
oldnjguy
Sep 10, 2015 02:39 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
