help can`t hit third gear
Old Feb 9, 2006 | 11:07 AM
dustindu4's Avatar
9 is not my lucky number.
The Hurst should help, I think your Saleen might just be binding.
Old Feb 10, 2006 | 01:23 PM
av99gt's Avatar
Not being able to get 3rd gear has nothing to do with the saleen short throw, unless you installed it backwards.
Old Feb 20, 2006 | 05:48 PM
Infinity's Avatar
I've noticed the same issue with 3 different 05+ GT's I have driven. Paul's High Performance even makes a part to solve the problem, and yes, it seems to be torque related.
http://secure-order-area.net/paulshp/cgi-b...t_id=2132_29634
Old Mar 1, 2006 | 11:16 AM
kampendmk's Avatar
Installed hurst shifter it`s was easy it took about hour .The shifter is taller fills like your driving a different car more shift control
Old Mar 1, 2006 | 01:06 PM
Shea's Avatar
Good, we can finally let this topic drop off the list, I'm sick of seeing it.
Old Mar 3, 2006 | 09:21 PM
kampendmk's Avatar
Installed hurst shifter and ran 8.957 at irwindale last nite 1/8 mile track .I figured out the problem if you slam it hard into second gear won`t go into 3rd .
Old May 6, 2006 | 10:47 AM
mikeelia's Avatar
I'm not sure exactly what the problem here is, but I will add that sometimes just driving around I have trouble getting the stock shifter into third: It feels almost like there is a "lip" that it catches on between the first and thrd gear slots. Not very technical, I know...
Mike E
Rando
Aug 25, 2021 11:12 AM
NC14GT
Sep 10, 2017 04:47 PM
Detroit Steel
Sep 21, 2015 03:35 PM
tbear853
Sep 8, 2015 11:18 PM
