help with c&l heat shild please i have pics!!
Old Jan 20, 2007 | 09:10 AM
touring's Avatar
well here's the problem the heat shield dosent fit!!! my hood dosent even close by it self i have to force it down. Is this suppose to be like that?? here are the pics
Host Images with PicTiger
Old Jan 20, 2007 | 09:49 AM
cobra4548's Avatar
From your pics you have it installed wrong. Turn it around. In your pics you have an open spot by the ABS lines. There should not be a space. The back of the shield should be there. The open section should be against your strut tower.
Old Jan 20, 2007 | 10:09 AM
touring's Avatar
i dont get it
what do you mean, it cant be installed any other way. that's the only way the screw will screw in to the body
Old Jan 20, 2007 | 10:29 AM
GrabberPony.com's Avatar
Mine is mouted like this;
My hood closes just fine.
Is this how yours is mounted?
Mark
www.GrabberOrange.net
Old Jan 20, 2007 | 10:35 AM
HiRoller's Avatar
I have a C&L, but my airbox looks different. They must have changed the style.
Old Jan 20, 2007 | 10:59 AM
Doug@C&L's Avatar
The C&L does stick up just a bit but that is to help create a good seal between the hood and the engine bay to help prevent hot air from entering the air filter.
You may need to loose the TB hose and try and puch the MAF end of the tube down just abit but everything else looks fine. The hole for the ziptie should be right beside the ABS metal lines.
Thanks, Doug.
Old Jan 20, 2007 | 11:03 AM
touring's Avatar
here are some more pics
Upload Gif with PicTiger
mine dosent seem to fit like your i dont know what's wrong
Old Jan 20, 2007 | 11:07 AM
touring's Avatar
dont know
but in my second pick from the new batch i put up it's not next to the abs lines or is it???So i should loosen and push down on the rear of the intake tube,so thAT the hole intake lowers itself?
Old Jan 20, 2007 | 11:11 AM
touring's Avatar
between mine and safari they both look different
it's like it's 2 different types
Old Jan 20, 2007 | 11:23 AM
Elliot,
Try to loosen the hose clamps where the C&L Intake tube attaches to the Throttle Body and push the tube down a little. I suspect that you may have the tube set too high and it's pushing everything up (like the heat shield).
Once you get the heat shield in the right position you can re-tighten the clamps.
Mark
Old Jan 20, 2007 | 11:29 AM
TillmanSpeed's Avatar
Former Vendor
Exactly!
Loosen the clamp on the rubber coupler between the throttle body and the tube, but leave it on. Just enough so that you can freely move the intake. Push down on the spot around where the MAF sensor bolts in, while still holding the intake from coming away from the throttle body with your other hand. This should push the whole assembly down.
Chris
Also: Yes, C&L had 2 different heat shields come out. So you will see some people with your same shield, and some with the other shown in the post above.
Old Jan 20, 2007 | 11:38 AM
touring's Avatar
cool thanks alot guys
ill be heading to 1SG house later to see what up with it. again thanks alot
May 3, 2026 05:42 AM
AlphaM1
Aug 13, 2025 05:58 AM
Road_Runner
Sep 2, 2024 04:46 PM
