Help with Banging noise
My car has the front strut problem have not had fixed yet, but the last couple days I've noticed a simliar sound coming from the passenger side trunk area. Checked everything in the trunk it is all secure. Did not see anything obvious underneath. Any suggestions? Anyone else have this problem? 1100 miles, car built 3/05
i guess i have the same problem. i can hear that noise when i hit the brake.
i took it in for service but they obviously have no idea what to do with that!
they had my car for 2 days and they think the rear noise is somewhat related to the front strut problem. so the result: "we try to fix front strut problem and HOPEFULY it will take care of that rear noise. if not we'll try something else...". so now i'm waiting for front suspension parts... for over a month!
Grab your passenger side tailpipe and pull back or up and down.You might just find your banging here.
I had a noise and it drove me crazy. I got under the car moved the exhaust around etc. and just could not find it till the other day. When I installed my X pipe I had to realign my tailpipes and right above the tip there is a flat piece of metal hanging down and my tip was hitting it on bumps. I moved the tips down a hair and now shes quiet as new It may not be the case for you, but I didn't see it at first so you may go back and look.
Thanks Mike
Thanks Mike
05redfiregt Posted June 18, 2005, 10:03 AM
mine had the noise as well. then i looked in the rear view mirror and noticed a really hot girl humping the rear passenger fender.
did you guys look to see if that was a root cause??
I had a weld that holds the rear seatbelt that made a clicking type noise and it sounded like it was comming from the rear deck. It was annoying. My swaybar was also comming loose and was making a noise that sounded like it was comming from the rear because it was resonating through the whole chassis.
Rando
8/25/21 11:12 AM
