Header gasket
Old Oct 5, 2008 | 06:11 PM
SONICBOOST's Avatar
Header gasket
Is it better to buy a new header gasket from the dealer or use the one supplied in the kit? This will be for mac longtubes. Thanks
Edit- I forgot the mac longtubes do not come with header gaskets. Can I just pick up a set at a local ford?
Old Oct 5, 2008 | 06:55 PM
n8rfastback's Avatar
re-use your stockers.... they come out just fine and are easily reusable....
many on here have done that.
if your not cool with that, order some new stock ones from ford.
Old Oct 5, 2008 | 08:26 PM
surf808's Avatar
Just reuse your stock ones. No problems since the install.
Old Oct 5, 2008 | 08:52 PM
officespace56's Avatar
+1 Stockers holding strong for over a year now
Old Oct 5, 2008 | 09:24 PM
JonCo's Avatar
If I remember correctly I have stock gaskets and its good.
BTW, you might see a drop in high end PSI with the L/Ts. Least I did, my Vortech kit wasn't able to make 10psi with the 3.60" pulley. I only saw 7psi at 6300RPM. I had to swap into a 3.33" pulley(purchased from Brenspeed) to make the psi.
Shop said you lose back pressure with the LTs. Are you doing O/R prochamber also? Your going to love the sound.
Old Oct 5, 2008 | 10:35 PM
SONICBOOST's Avatar
Not sure if I wanna throw on the longtubes yet but i will be putting these in place of my stock cats for now to go with my prochamber and pypes mid muffler. Shouldn't sound too bad..
More Images
Brand Eastern CatalyticPart # 79125Availability Ships within 2-3 Days
Shipping Cost
$0 Only to lower 48 statesOur Price
$149.95 Tell a Friend
PRODUCT DESCRIPTION
FREE Shipping! The Eastern Bullet Cat is your ultra-high performance converter solution. The robust stainless construction and 200 cell metal matrix technology makes it the ideal choice for supercharged, turbocharged, nitrous oxide, and all race applications!
Sold individually.
200 cells per square inch metallic catalyst allows for significantly better flow than standard 400 cell catalysts.
Metallic substrate withstands extreme temperatures and vibration that can melt or crumble ceramic catalysts.
Fully welded/spun construction with no mechanical seams that can leak or open up under stress.
Compact, stainless steel can resists corrosion, fits easily in tight applications.
Inlet/Outlet ID: 2.50"
Body Length: 6.5"
Overall Length: 10.5"
Ships in 2-3 days.
wallace
Mar 29, 2016 10:09 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
FromZto5
Sep 30, 2015 05:28 AM
billy y
Sep 24, 2015 11:48 AM
Beouch
Sep 16, 2015 06:14 PM
