Getting better gas mileage...
Old Aug 26, 2005 | 01:25 PM
Hatchman's Avatar
To be honest, I wouldn't believe it if I didn't see it, but I'm getting about 1.5 mpg better gas mileage since I put in Amsoil full synthetic motor oil in my car.
Don't get me wrong, I didn't buy a V8 muscle car to get good gas mileage, I'm just noting that this oil made a difference.
On the average, if I dawg it and during break in, I got about 14mpg. If I go max conserve, I get 20, and driving normal, about 16, and going max range (getting to work as fast as I can without a ticket), I get about 16. But after changing my oil to full synthetic at 3500 miles, I'm getting over a mpg better in every type of driving. This is driving about 15 miles one way averaging 40 mph with a few stops.
Just thought I'd share. Any one else seen a difference with syn?
Old Aug 26, 2005 | 01:27 PM
MaverickMLFD371's Avatar
im going in for my 15,000 check up, switching to full synthetic Mobil 1, I've been using the Mobil 1 Syntec Blend, nows a good time to change her
Old Aug 26, 2005 | 02:34 PM
The Lyin' King's Avatar
I switched to Mobile 1 full synthetic at 2500 miles in both the engine and manual transmission. Tank average = 23-25
Old Aug 26, 2005 | 02:35 PM
300HPGT's Avatar
I switched at 3000 miles.
Old Aug 26, 2005 | 02:36 PM
300HPGT's Avatar
When should you change manual transmission fluid?? and how do you on our cars?
Old Aug 26, 2005 | 02:37 PM
BigDog's Avatar
Just did my first oil change and went with a synthetic blend. I'm curious to see if there's any improvement.
I got the most improvement in mileage out of turning off the a/c and the traction control, tho. Shocked the poo out of me, but now I'm getting around 24 mpg in general and 30 mpg on the highway!
Old Aug 26, 2005 | 03:48 PM
Never too early IMO . . . get the debris from break-in out.
It's the SOP, there's a drain plug . . . on the bottom back near rear of the tranny, takes a 3/8 drive ratched head. Then there's a fill plug on the right side a few inches forward of the drain, 3/8 too.
You'll need to either pump the fluid up into the hole or gravity feed it down via a funnel/hose setup. 3.2 quarts of Mobile 1 Full Synthetic (*Mercon compatible) ATF is what I tossed it there.
Old Aug 26, 2005 | 03:49 PM
Synthetic Blend is what it ships with from the factory.
Old Aug 26, 2005 | 04:52 PM
300HPGT's Avatar
yeah i have done some slight gear grinding since its my first ever manual car. so it needs to be changed. you used ATF in there?????
Old Aug 26, 2005 | 10:10 PM
Hatchman's Avatar
Yes, Ford has been using ATF in manual transmissions for years now. Go figure. :scratch: I've got some Amsoil ATF in the garage, probably do that next week.
Old Aug 26, 2005 | 10:21 PM
Mpaps
Oct 11, 2017 08:06 PM
NC14GT
Sep 10, 2017 04:47 PM
mx5jhb
Sep 30, 2015 04:44 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
