fuel pump replacement
Brad - wish I could be more specific - but I do know there are two large access holes under the rear seat cushion (one per side) that are covered with rubber access covers and could easily be pulled to check - they do appear to acces the front of the fuel tank area....
Just curious - why won't warranty cover the replacement - you can't have 36K on your '05 yet
there are 3 bolts to remove. One in the center, 2 on each side. If you fold down the seat, you'll find the one in the middle. pull back on the corner of the seat section and you'll see the other 2. Then there are two release clips in front and it just pops up. I looked under those caps and I don't recall what they are for though. I think there was a bolt there. Maybe to the tank strap?
under the back seat, or drop the tank?
Does anyone know if the Mustang has a fuel return system or is it returnless?
Rando
8/25/21 11:12 AM
PonyMuscletang13
9/29/15 09:40 AM
