fuel pump replacement
Old Apr 18, 2005 | 05:23 PM
O5GT's Avatar
under the back seat, or drop the tank?
ford labor shows 2 hrs,
anyone able to chime in?
thanks
Brad
Old Apr 18, 2005 | 05:58 PM
HOTLAP's Avatar
Brad - wish I could be more specific - but I do know there are two large access holes under the rear seat cushion (one per side) that are covered with rubber access covers and could easily be pulled to check - they do appear to acces the front of the fuel tank area....
Just curious - why won't warranty cover the replacement - you can't have 36K on your '05 yet
Old Apr 18, 2005 | 06:31 PM
O5GT's Avatar
the supercharger kit comes with one
Old Apr 18, 2005 | 06:32 PM
O5GT's Avatar
how does the back seat come out?
Old Apr 18, 2005 | 08:02 PM
169stang's Avatar
there are 3 bolts to remove. One in the center, 2 on each side. If you fold down the seat, you'll find the one in the middle. pull back on the corner of the seat section and you'll see the other 2. Then there are two release clips in front and it just pops up. I looked under those caps and I don't recall what they are for though. I think there was a bolt there. Maybe to the tank strap?
Old Apr 24, 2005 | 05:19 AM
Stang281's Avatar
Does anyone know if the Mustang has a fuel return system or is it returnless?
Old Apr 24, 2005 | 06:08 AM
Tiberius1701's Avatar
Under the back seat bottom, seat bottom is really easy to remove-just use a screwdriver to release the two retaining tabs at the front edge of seat bottom about 10-12" inboard of the seat's outer edge and lift the seat cushion out of vehicle. When reinstalling the seat bottom be sure to thread the buckles through their holes before locking down the cushion.
All Mustangs use a returnless fuel system.
Old Apr 25, 2005 | 09:27 PM
O5GT's Avatar
i have the vortech instructions now, but still no kit, the pump is removed from under the back seat, so thats a plus
lakersfreak
Jun 13, 2022 12:29 AM
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
