Frpp Cams
Old 3/11/08, 05:53 PM
  #81
70MACH1OWNER's Avatar
Location: New Carlisle, Ohio (20 miles north of Dayton)
Originally Posted by polodinks
ya but with my luck the day i have them put in, is the day somthing happens to my car and decide to take it to the dealer
Hey Polo,
This world is full of "pay your money and take your chances" It's your decision!! But take this from an old man. "life is very short!!
Scott
Old 3/11/08, 07:27 PM
  #82
SoundGuyDave's Avatar
Hey Polo,
Scott
+1,000,000... I couldn't have said it better...
Old 3/12/08, 07:52 AM
  #83
RKNMACH's Avatar
What a great sound. Still have to wonder if the emissions will be affected if you add the cams. Anyone have any real data on this issue or are we still pondering/guessing?
Old 3/12/08, 08:02 AM
  #84
FordRacing's Avatar
Absolutely the emissions will be effected. but unless you live somewhere where they sniff the exhaust you will be fine. I know you can't install these in Cal, or Denver.
Here in NY all you have to do is keep all the emission equipment and the ECU can't be throwing any codes.
Old 3/12/08, 09:11 AM
  #85
RKNMACH's Avatar
I live in Virginia and they just read the ECU so it shouldn't be an issue. Sounds like the Wolverine cam I had in my 69 Mach 1 only badder.
Old 3/12/08, 09:17 AM
  #86
superman112's Avatar
Ford Racing, where in Ny are you? I'm in Middletown NY.
Old 3/12/08, 10:17 AM
  #87
FordRacing's Avatar
South of Buffalo
Old 3/12/08, 11:57 AM
  #88
Originally Posted by FordRacing
South of Buffalo
ahh... must still be pretty freakin cold up there huh? Best of luck with the cams.
Old 3/12/08, 03:02 PM
  #89
FordRacing's Avatar
yeah....and I'm getting mighty sick of it too...
Old 3/12/08, 03:37 PM
  #90
Forge's Avatar
Ive listened to alot of the BBR, comp stag 2,3 and 4 and they all sound about the same.
I havent been able to find a good clip of the brenspeed cams. I am guessing it sounds about the same as well.
When i get around to doing the same, i will be picking the cheapest from Brenspeed, Comp and BBR as the performance and sound seem to be about the same for all of them.
Old 3/12/08, 04:21 PM
  #91
jared188's Avatar
Fordracing I hope your right about NY... I want to get these cams for my car when they come out.
Old 3/12/08, 05:13 PM
  #92
FordRacing's Avatar
The only place I hear the NYSI is different is NYC.
Old 3/20/08, 10:15 AM
  #93
jared188's Avatar
I really wish these were out I want to get them for my car before I start driving it all the time.
Old 3/20/08, 10:23 AM
  #94
blkstang06's Avatar
Heres a clip of 70MACH1OWER's NSR Comp cams on his Vert !
http://s138.photobucket.com/albums/q...thCompcams.flv
Old 3/20/08, 06:36 PM
  #95
Thanks STD!!! While I did get to drive the car today for only the second time since the cams were installed on Feb. 15th. I can tell you that the Comp NSR cams definitely have a rougher idle than the stockers, it is nothing like the BBR cam video clips I have heard posted. But I got to tell you that it sounded awesome going thru the drivethru tonight after work..My video does not really capture the idle difference. I might try another vid to see if the lopeyness will show up better. But again it is not as radical as the BBR cams!
Scott
Old 3/20/08, 08:37 PM
  #96
blkstang06's Avatar
Scott
Scott, you need to make another clip moving around the car I think the problem on any cam clip is when the exhaust kinda drowns out the motor!.... Well you don't have to make another clip but it would be cool ! ! !.....
Old 3/21/08, 09:26 AM
  #97
Dixie_Flatline's Avatar
And at least pull it out of the garage, the sound reflections from the garage/cave acoustics are probably overlapping that awesome lope.
Anybody ever find out how much the FRPP cams are going to cost?
Old 3/21/08, 09:50 AM
  #98
FordRacing's Avatar
Sutton has them for 739.00
Old 3/21/08, 02:34 PM
  #99
Your right but since I did a vid at idle with the stock cams in the same place I was trying to show the difference in the stock verses the Comp NRS cams but you only linked to the Comp cams. I know your getting old so I forgive you.
Okay Dixie,
Since you asked for me to move out of the garage and the sun was shining when I go home I will try to please. So here is my Comp NRS cams at idle. Definitely rougher than stock but no where are lopely as the BBR cams. See if this helps.
Scott
http://s138.photobucket.com/albums/q...amsoutside.flv
Old 3/21/08, 02:40 PM
  #100
turbo05gt's Avatar
your idle sounds really high?
Quick Reply: Frpp Cams
