front end clunk more questions...
Old Apr 24, 2007 | 09:33 AM
YaoNYC's Avatar
hi all and thanks in advance.
i did tokicko d-spec and eibach pro springs and there is A LOT of clunking on my front end. its very very annoying at this point. it makes my Stang feel cheap and a rattle box
does anyone know definitely what the issue(s) are?
i know this has been asked before on previous posts but i am not sure what the final answers are.
any experience and clarification would be great! thanks!
Old Apr 24, 2007 | 09:51 AM
max2000jp's Avatar
Tighten up your sway bar endlinks.
Old Apr 24, 2007 | 10:08 AM
YaoNYC's Avatar
thanks very much max2000jp.
i'll definitely get on that....
Old Apr 27, 2007 | 08:21 AM
YaoNYC's Avatar
hi all...
so, here is what i been gathering from a lot of you and thanks in advance!
1. check front sway bar end link bolts (as max2000 mentioned on this thread)
2. steeda strut mounts
that should solve it!
anything else that can add to these clunking noises?
thanks!
Old Apr 27, 2007 | 08:51 AM
05YellowGT's Avatar
If it's what most of us had , the Steeda strut mounts totally did away with it on my car ...
Old Apr 27, 2007 | 09:04 AM
YaoNYC's Avatar
thanks 05yellow.
looks like with the combined help of many users here, we found the issue with the many different clunking problems!
Old Apr 27, 2007 | 04:08 PM
official_style's Avatar
bro, u got clunks in the back too lol. its gotta be loose bolts!
Old Apr 27, 2007 | 04:31 PM
RadBOSS's Avatar
Well is the nut on the end of the strut rod that holds it to the upper bearing tight and correctly torqued?
Did you install the upper bearing mount with the index key in the right direction?
With the hood up and someone pushing up and down on the car, can you feel the clunk at the upper bearing where the strut rod comes thru it?
What shock setting did you set the Spec-D's to?
Fords4Ever
Oct 30, 2015 09:07 PM
FromZto5
75
Oct 5, 2015 02:27 PM
seaclam
Sep 25, 2015 01:29 PM
tbear853
Sep 8, 2015 11:18 PM
robjh22
Sep 8, 2015 12:31 PM
