Flucuating rpm
Old Feb 24, 2008 | 11:36 AM
BlackSnakeMoan's Avatar
Flucuating rpm
It goes up and down for a minute then settles. Do you know whaat might cause that?
Old Feb 24, 2008 | 11:48 AM
Robbieg's Avatar
Might try cleaning your MAF sensor. Has it always done this or did the problem just develop?
Old Feb 24, 2008 | 11:52 AM
DavidM's Avatar
Need more info. Is this at startup? After it has run and is hot? More details man!
Old Feb 24, 2008 | 08:18 PM
tdbrown75's Avatar
Could be a vacuum leak, check your intake connections!
Tim
Old Feb 24, 2008 | 08:20 PM
billr814's Avatar
factory airbox is very constricted..also has a filter you don't see in the elbow part going to throttle body..
Old Feb 24, 2008 | 08:22 PM
theedge67's Avatar
Only the early 05's have that extra filter in the elbow. We don't even know what year car he has, he gave no info at all about his car or his situation.
Old Feb 25, 2008 | 01:37 PM
cmplxlgc's Avatar
That's a very limited question....
Dirty MAF?
Cold weather start?
Higher than average idle?
Leak?
*To OP: Colder weather yields higher rpms @ start-up. Mine sits @ 1K for about 5-10secs and levels to 750 (tuned).
Old Feb 25, 2008 | 02:43 PM
G.T's Avatar
G.T
my money is on a dirty throttle body.
clean up the carbon/oil build up on and around the throttle body plates and you should be running fine.
Old Feb 25, 2008 | 05:42 PM
anthony05gt's Avatar
I would clean the TB and MAF sensor.
That thing in the intake elbow on the early '05's was a device used to trap any unburned fuel vapors that may try to escape to the atmosphere through the airbox....emission control device.
Old Feb 25, 2008 | 06:29 PM
DoctorQ's Avatar
Originally Posted by BlackSnakeMoan
It goes up and down for a minute then settles. Do you know what might cause that?
I've got an 06GT... does the exact same thing. Right after starting, RPMs go up and down rapidly between 800 and 1200, but only for about 30 seconds, then it settles down to perfect idle. Did it when I had the stock intake on.. and does it now after I have my C&L street intake on. I've checked connections, cleaned TB & plates, cleaned MAF sensor... no affect... still oscillates between it's narrow band for 30 seconds, then all is good. Post if you solve the mystery.
Old Feb 25, 2008 | 06:54 PM
tom281's Avatar
Like the other guys have said, we need more info.......including what (if any) mods you have on your car.
Glenn
73
Apr 26, 2016 12:22 PM
Fastnloud
Feb 15, 2016 05:21 PM
trackpack13gt
Aug 8, 2015 11:23 AM
goocher625
1994-2004 V-8
Jul 15, 2015 08:08 AM
