Is this a driveshaft problem
Old Mar 7, 2008 | 09:21 PM
btrokc's Avatar
Installed an alum SpyderShaft and am getting a vibration up thru my shifter lever at speeds above 70. It really makes a racket. The driveshaft wae one of several mods I did at the same time. I am trying to determine what has caused this vibration and what to do about it. I have a Hurst shifter, BMR driveshaft loop, BMR uca and panhard bar. I do not think any of the other mods could be causing the problem. Some others have had DS vibrations so they may recognize the symtoms. For those who have had problems, how did you solve the problems. Thanks.
Old Mar 7, 2008 | 09:30 PM
SoundGuyDave's Avatar
First off, are the UCA or the Metco LCAs adjustable or fixed? The Steeda sport springs give you about a 1.25" drop? Your pinion angle may be off. Also, try pulling the DS, rotating 180* and reinstall, that cures a lot of the issues others have had.
Old Mar 7, 2008 | 09:54 PM
btrokc's Avatar
The UCA is adjustable but the LCAs are not. We did set the pinon angle. I will try rotating the driveshaft. Thanks.
Old Mar 7, 2008 | 11:00 PM
tom281's Avatar
Sounds like a shaft problem for sure...... try the suggestion above. Hope you installed the pinion flange correctly- if not, you'll have even bigger problems down the road.
Old Mar 8, 2008 | 03:35 PM
70MACH1OWNER's Avatar
I agree with Tom. I installed my Spydershaft back around Xmas and I did not get the new pinion flange seated correctly. Even though I set my torque wrench at 150 ft/lbs. it did not seat. I also had a gear whine and lost a little differential fluid. I only drove the car a couple of hundred yards before I knew it wasn't correct. I had my car towed to a guy that has done my gear work on past stangs and he fixed it really quick. It needed more torque than 150 lb.s to re-seat the new flange. If you are not comfortable doing it yourself just have the car towed to someone who can fix it. I really doubt that the driveshaft is not balanced correctly. Make sure both ends of the shaft are seated properly. If all else fails call Ron @ Lenord racing.
Scott
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
