drive line roar
Old Apr 6, 2010 | 09:10 PM
06SatinSilver's Avatar
drive line roar
been getting a driveline "roar" from the rear end/shaft when letting off the gas in 5th and 4th at high speeds...only happens when off the gas rpms coming down (coasting) ...the higher the speed the worse it is... any thoughts?
I was thinking: diff/trak lock not unlocking?? clutchpacks worn out?? ....fluid level is good...car has 25k on it. nothing strange otherwize happening...no funny noises or vibes on accel or cornering.
Old Apr 7, 2010 | 08:23 AM
Can't hurt to get under the car and take a look at the diveshaft to pinion bolts, pinion seal, etc.. to see if anything is loose or is leaking.
Old Apr 8, 2010 | 08:34 PM
cave diver's Avatar
Almost sounds like the lash on the pinion bearing is too loose. Did you put new gears in it after you bought it?
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
AMWill
Jul 16, 2015 04:26 PM
BillyDaKid
V6 Performance Mods
Jul 15, 2015 12:50 PM
